Ir para o conteúdo principal
How to Repair a Warped Cooking Pan
O que você precisa
  1. How to Repair a Warped Cooking Pan, How to Repair a Warped Cooking Pan: passo 1, imagem 1 %32
    • Locate the hard surface you will use for the repair.
  2. How to Repair a Warped Cooking Pan: passo 2, imagem 1 %32
    • Place one of the two towels on top of the hard surface.
  3. How to Repair a Warped Cooking Pan: passo 3, imagem 1 %32
    • Turn on the stove to medium heat to warm up the bottom of the cooking pan that is warped.
  4. How to Repair a Warped Cooking Pan: passo 4, imagem 1 %32
    • As soon as the pan is warm or hot to the touch, quickly remove it from the stove.
    • Turn off the stove and place the pan, bottom up, on top of the towel that is placed on the hard surface.
  5. How to Repair a Warped Cooking Pan: passo 5, imagem 1 %32 How to Repair a Warped Cooking Pan: passo 5, imagem 2 %32
    • Place the second towel on top of the bottom of the pan that is facing upward.
  6. How to Repair a Warped Cooking Pan: passo 6, imagem 1 %32
    • Place the block of wood on top of the second towel that is placed on the pan.
  7. How to Repair a Warped Cooking Pan: passo 7, imagem 1 %32 How to Repair a Warped Cooking Pan: passo 7, imagem 2 %32
    • Carefully hammer directly onto the block of wood.
    • Make sure that the block of wood is still firmly on top of the bottom of the pan. This will help ensure that the pan is repaired properly.
  8. How to Repair a Warped Cooking Pan: passo 8, imagem 1 %32
    • Your cooking pan should no longer be warped. You are finished!
Linha de Chegada
angieaguirre
Membro desde: 02/21/24
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 129
