Ir para o conteúdo principal
How to Repair a Tear in a Camping Chair
O que você precisa
  1. How to Repair a Tear in a Camping Chair, Identify the repair area: passo 1, imagem 1 %32 How to Repair a Tear in a Camping Chair, Identify the repair area: passo 1, imagem 2 %32
    • Locate the tear that needs to be fixed.
  2. How to Repair a Tear in a Camping Chair, Unscrew the back of the chair: passo 2, imagem 1 %32 How to Repair a Tear in a Camping Chair, Unscrew the back of the chair: passo 2, imagem 2 %32 How to Repair a Tear in a Camping Chair, Unscrew the back of the chair: passo 2, imagem 3 %32
    • Use a screwdriver to disassemble the chair and then remove the parts piece by piece.
  3. How to Repair a Tear in a Camping Chair, Disassemble the rest of the chair: passo 3, imagem 1 %32 How to Repair a Tear in a Camping Chair, Disassemble the rest of the chair: passo 3, imagem 2 %32 How to Repair a Tear in a Camping Chair, Disassemble the rest of the chair: passo 3, imagem 3 %32
    • Continue to take the pieces and set them aside until you reach the fabric that needs to be stitched.
    • In this step, you simply need to use your hands to slide off and gently remove each part.
  4. How to Repair a Tear in a Camping Chair, Organize the repair area: passo 4, imagem 1 %32 How to Repair a Tear in a Camping Chair, Organize the repair area: passo 4, imagem 2 %32 How to Repair a Tear in a Camping Chair, Organize the repair area: passo 4, imagem 3 %32
    • Set aside all the components of the chair, sort them out in small groups and prepare for stitching.
  5. How to Repair a Tear in a Camping Chair, Prepare the piece of cloth: passo 5, imagem 1 %32 How to Repair a Tear in a Camping Chair, Prepare the piece of cloth: passo 5, imagem 2 %32 How to Repair a Tear in a Camping Chair, Prepare the piece of cloth: passo 5, imagem 3 %32
    • Use a pair of scissors to cut a piece of cloth.
    • Note: we recommend using a piece of cloth that matches the material of the torn fabric. In this example, we used a non-stretch fabric that had a similar texture and feel to the original.
    • Place the cloth underneath the tear and get ready for the next step.
  6. How to Repair a Tear in a Camping Chair, Prepare for stitching: passo 6, imagem 1 %32 How to Repair a Tear in a Camping Chair, Prepare for stitching: passo 6, imagem 2 %32 How to Repair a Tear in a Camping Chair, Prepare for stitching: passo 6, imagem 3 %32
    • Use sewing pins to fix the piece of cloth in place. Put the pins around the tear, forming a "square" shape (green lines).
  7. How to Repair a Tear in a Camping Chair, Start sewing: passo 7, imagem 1 %32 How to Repair a Tear in a Camping Chair, Start sewing: passo 7, imagem 2 %32 How to Repair a Tear in a Camping Chair, Start sewing: passo 7, imagem 3 %32
    • Use a straight stitch to sew a "square shape" around the tear.
    • Tip: For tips on setting up the machine take a look at this iFixit guide.
    • Rotate the piece as much as you need to find the position that makes the stitching more comfortable.
    • Once you have completed the stitch, use a pair of scissors to clean the loose threads.
  8. How to Repair a Tear in a Camping Chair, Reinforce the stitch: passo 8, imagem 1 %32 How to Repair a Tear in a Camping Chair, Reinforce the stitch: passo 8, imagem 2 %32 How to Repair a Tear in a Camping Chair, Reinforce the stitch: passo 8, imagem 3 %32
    • Adjust the sewing machine to the Zig-Zag stitch setting and the length to "3".
    • Stitch a diagonal line following the direction of the red arrow.
  9. How to Repair a Tear in a Camping Chair, Clean the area: passo 9, imagem 1 %32 How to Repair a Tear in a Camping Chair, Clean the area: passo 9, imagem 2 %32 How to Repair a Tear in a Camping Chair, Clean the area: passo 9, imagem 3 %32
    • Use a pair of scissors to cut the loose parts around the stitch and clean the area.
  10. How to Repair a Tear in a Camping Chair, Reassemble the chair: passo 10, imagem 1 %32 How to Repair a Tear in a Camping Chair, Reassemble the chair: passo 10, imagem 2 %32 How to Repair a Tear in a Camping Chair, Reassemble the chair: passo 10, imagem 3 %32
    • Start by putting the components back, first the repaired fabric and then the rest of the parts.
    • Screw back the pieces that were taken on the previous steps.
  11. How to Repair a Tear in a Camping Chair, Finished and ready!: passo 11, imagem 1 %32 How to Repair a Tear in a Camping Chair, Finished and ready!: passo 11, imagem 2 %32 How to Repair a Tear in a Camping Chair, Finished and ready!: passo 11, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 156
