Ir para o conteúdo principal
How to Repair a Stuck or Broken Chainsaw Rope
O que você precisa
  1. How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: passo 1, imagem 1 %32 How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: passo 1, imagem 2 %32
    • Remove the chainsaw casing or handle.
    • This step will vary depending on what kind of chainsaw you are using. Some might only require you to remove the handle, while others have a casing you must remove instead.
  2. How to Repair a Stuck or Broken Chainsaw Rope: passo 2, imagem 1 %32
    • Remove the screw on top of the housing.
  3. How to Repair a Stuck or Broken Chainsaw Rope: passo 3, imagem 1 %32 How to Repair a Stuck or Broken Chainsaw Rope: passo 3, imagem 2 %32
    • Remove the housing unit.
  4. How to Repair a Stuck or Broken Chainsaw Rope: passo 4, imagem 1 %32 How to Repair a Stuck or Broken Chainsaw Rope: passo 4, imagem 2 %32
    • Remove the rope from the chainsaw using a pair of pliers.
  5. How to Repair a Stuck or Broken Chainsaw Rope: passo 5, imagem 1 %32
    • Make your adjustments to fix any problems with the rope.
    • The adjustments needed to be made will vary depending on your specific problem with the rope.
  6. How to Repair a Stuck or Broken Chainsaw Rope: passo 6, imagem 1 %32
    • Stick the rope back through the insertion hole.
  7. How to Repair a Stuck or Broken Chainsaw Rope: passo 7, imagem 1 %32
    • Stick the housing back onto the casing.
    • Do not screw the housing on yet.
  8. How to Repair a Stuck or Broken Chainsaw Rope: passo 8, imagem 1 %32
    • Twist the housing unit until the tension is maxed out.
    • Caution: Once the tension is maxed out, you must hold the housing unit firmly or else it will slide out and possibly hit you or someone nearby.
  9. How to Repair a Stuck or Broken Chainsaw Rope: passo 9, imagem 1 %32 How to Repair a Stuck or Broken Chainsaw Rope: passo 9, imagem 2 %32
    • Stick the rope through the groove into the housing.
  10. How to Repair a Stuck or Broken Chainsaw Rope: passo 10, imagem 1 %32
    • Re-tie the rope into a knot.
  11. How to Repair a Stuck or Broken Chainsaw Rope: passo 11, imagem 1 %32 How to Repair a Stuck or Broken Chainsaw Rope: passo 11, imagem 2 %32
    • Slowly rewind the housing unit until the rope is back into its original position.
  12. How to Repair a Stuck or Broken Chainsaw Rope: passo 12, imagem 1 %32
    • Re-screw any screws used to take off the housing.
    • This step will vary. Not all chainsaws will have extra screws on their housing unit.
  13. How to Repair a Stuck or Broken Chainsaw Rope: passo 13, imagem 1 %32
    • Place the casing or handle back onto the chainsaw.
    • Similarly to Step 1, this will vary depending on the type of chainsaw you are using.
  14. How to Repair a Stuck or Broken Chainsaw Rope: passo 14, imagem 1 %32
    • Pull on the rope to make sure the chainsaw works.
Linha de Chegada
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 585
