Ir para o conteúdo principal
How to Repair a Stuck Toilet Handle
O que você precisa
  1. How to Repair a Stuck Toilet Handle, How to Repair a Stuck Toilet Handle: passo 1, imagem 1 %32 How to Repair a Stuck Toilet Handle, How to Repair a Stuck Toilet Handle: passo 1, imagem 2 %32
    • Find the shut off valve behind the toilet.
    • To close the shut off valve, most toilet valves need to be turned to the left.
  2. How to Repair a Stuck Toilet Handle: passo 2, imagem 1 %32 How to Repair a Stuck Toilet Handle: passo 2, imagem 2 %32
    • Remove the lid from the tank of your toilet.
    • Find the nut inside of the tank that holds your toilet’s lever.
  3. How to Repair a Stuck Toilet Handle: passo 3, imagem 1 %32
    • Using your hand or an appropriately sized wrench, loosen the nut a little.
    • If your toilet handle is still sticking, move to the next step.
  4. How to Repair a Stuck Toilet Handle: passo 4, imagem 1 %32
    • Push the handle down slowly and watch the lever arm to make sure it is not touching anything.
    • The lever arm of your toilet handle cannot touch anything or else it might cause the handle to stick.
  5. How to Repair a Stuck Toilet Handle: passo 5, imagem 1 %32 How to Repair a Stuck Toilet Handle: passo 5, imagem 2 %32
    • If your toilet’s lever arm is touching something, bend the metal so that this does not happen.
  6. How to Repair a Stuck Toilet Handle: passo 6, imagem 1 %32 How to Repair a Stuck Toilet Handle: passo 6, imagem 2 %32
    • If your toilet’s lever arm is catching on the chain which connects it to the flapper at the bottom of the tank, then this will need to be remedied.
    • The length of the toilet chain can be adjusted by moving the hook a few links down and reattaching it to the lever.
Conclusão
To reassemble your toilet, turn the water valve back on and put the lid back on.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 22
Ao todo: 1,029
