Introdução
If a car door suddenly will not close, it may be due to a stuck car door latch. Sometimes a latch may become stuck if someone accidentally knocked it into a locked position while the door was open. On many newer cars, simply pulling the interior or exterior door handle may reset the latch, but in cases where that is not enough, this guide will describe how to manually reset the latch.
O que você precisa
On the car door that will not close, examine the door latch located near the handle on the side of the door.
10 outras pessoas executaram este guia.
14 comentários
Thanks a lot, you have saved me from one !&&* of a problem!
This helped me so much!! Thank you!!!
Perfect. So simple. Excellent advice once again from iFixit. Thank you.
Thank you so much! I figured it out because of this post!
I love this solution. It literally just saved me. Thank you soo much.
