Ir para o conteúdo principal
How to Repair a Sole Delamination From the Midsole
O que você precisa
  1. How to Repair a Sole Delamination From the Midsole, Check the damaged area: passo 1, imagem 1 %32 How to Repair a Sole Delamination From the Midsole, Check the damaged area: passo 1, imagem 2 %32
    • Identify the part of the midsole that needs to be repaired.
  2. How to Repair a Sole Delamination From the Midsole, Remove glue residue: passo 2, imagem 1 %32 How to Repair a Sole Delamination From the Midsole, Remove glue residue: passo 2, imagem 2 %32
    • Use a rough piece of sandpaper to rub-off the remaining glue residue and to roughen the surface for enhanced glue adhesion.
    • Be careful not to damage the material below the midsole.
  3. How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: passo 3, imagem 1 %32 How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: passo 3, imagem 2 %32 How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: passo 3, imagem 3 %32
    • Apply the glue to both the sole and the separated part.
    • Apply pressure using clamps.
    • Note: Follow the instructions of the glue used to know the exact drying time. In this example we left the product to dry overnight.
  4. How to Repair a Sole Delamination From the Midsole, Finished and ready!: passo 4, imagem 1 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro desde: 07/19/23
10.230 Reputação
Autoria de 66 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
25 Membros
Autoria de 169 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 70
Ao todo: 818
