Introdução
This guide will show you how to fix a broken silent wall clock due to a faulty movement mechanism. This guide will learn how to fix the clock to its working order. During the process of this you are required to use only one household tool and with that it won’t take a lot of time and energy. Majority of people who own wall clocks do not reuse them as they see no usage when the battery dies from a wall clock or the clock timing is wrong. This repair information is needed because it is helpful to save you from spending money on replacing your Wall Clock with a new one.
O que você precisa
Using a screwdriver, remove all the screws on the back of the clock.
5 outras pessoas executaram este guia.
2 comentários
catellano por favor.gracias.
