Ir para o conteúdo principal
How to Repair a Silent Wall Clock Mechanism
O que você precisa
  1. How to Repair a Silent Wall Clock Mechanism, How to Repair a Silent Wall Clock Mechanism: passo 1, imagem 1 %32
    • Using a screwdriver, remove all the screws on the back of the clock.
  2. How to Repair a Silent Wall Clock Mechanism: passo 2, imagem 1 %32
    • Use your fingers to pry up one end of the battery and remove it from the clock.
  3. How to Repair a Silent Wall Clock Mechanism: passo 3, imagem 1 %32
    • Clean the battery terminals in the battery compartment using isopropyl alcohol and a cotton swab.
  4. How to Repair a Silent Wall Clock Mechanism: passo 4, imagem 1 %32
    • Dry the battery terminals with a clean cloth or paper towels so the terminals are not wet when a new battery is being inserted.
  5. How to Repair a Silent Wall Clock Mechanism: passo 5, imagem 1 %32
    • Once the terminals have dried up, remove the glass lens covering the faceplate of the clock to make any adjustments.
  6. How to Repair a Silent Wall Clock Mechanism: passo 6, imagem 1 %32
    • Turn the display face up, ensuring the clock hands do not touch each other.
    • Correct the time by moving the hands of the clock and inserting the new battery.
  7. How to Repair a Silent Wall Clock Mechanism: passo 7, imagem 1 %32
    • Put the faceplate back on and assemble all of the pieces of the clock.
Conclusão
5 outras pessoas executaram este guia.
Mohammad Kijera
Membro desde: 02/01/22
250 Reputação
Autoria de 1 guia
Equipe
2 comentários
catellano por favor.gracias.
mario oscar Fiori - Responder
You don't need to open the clock to set the time - just turn that circle dial on the backside of the clock! What is this guide "fixing" anyway??
Ari - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 26
Últimos 30 dias: 191
Duração total: 5,647
