Ir para o conteúdo principal
How to Repair a Seam Split in a Sleeping Bag
O que você precisa
  1. How to Repair a Seam Split in a Sleeping Bag, Identify the repair area: passo 1, imagem 1 %32 How to Repair a Seam Split in a Sleeping Bag, Identify the repair area: passo 1, imagem 2 %32
    • Locate the seam split that needs to be fixed.
  2. How to Repair a Seam Split in a Sleeping Bag, Prepare for stitching: passo 2, imagem 1 %32 How to Repair a Seam Split in a Sleeping Bag, Prepare for stitching: passo 2, imagem 2 %32 How to Repair a Seam Split in a Sleeping Bag, Prepare for stitching: passo 2, imagem 3 %32
    • Find a matching color thread and prepare the needle.
    • Make a double thread and add a little knot at the end.
  3. How to Repair a Seam Split in a Sleeping Bag, Start stitching: passo 3, imagem 1 %32 How to Repair a Seam Split in a Sleeping Bag, Start stitching: passo 3, imagem 2 %32 How to Repair a Seam Split in a Sleeping Bag, Start stitching: passo 3, imagem 3 %32
    • Make sure that the needle is in a position that is perpendicular to the edge of the seam (red arrow).
    • Take turns going up and down following line of the seam.
    • Note For this example we are doing an "invisible" stitch that provides a subtle solution to the split.
  4. How to Repair a Seam Split in a Sleeping Bag, Secure the stitch: passo 4, imagem 1 %32 How to Repair a Seam Split in a Sleeping Bag, Secure the stitch: passo 4, imagem 2 %32 How to Repair a Seam Split in a Sleeping Bag, Secure the stitch: passo 4, imagem 3 %32
    • Secure the stitch by pulling the thread tighter as you go.
    • Continue until you reach the end of the split.
  5. How to Repair a Seam Split in a Sleeping Bag, Clean the area: passo 5, imagem 1 %32 How to Repair a Seam Split in a Sleeping Bag, Clean the area: passo 5, imagem 2 %32 How to Repair a Seam Split in a Sleeping Bag, Clean the area: passo 5, imagem 3 %32
    • Add a knot at the end of the stitch.
    • Use a pair of scissors to clean the loose threads.
  6. How to Repair a Seam Split in a Sleeping Bag, Finished and ready!: passo 6, imagem 1 %32 How to Repair a Seam Split in a Sleeping Bag, Finished and ready!: passo 6, imagem 2 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 114
