Ir para o conteúdo principal
How to Repair a Scratched CD
O que você precisa
  1. How to Repair a Scratched CD, How to Repair a Scratched CD: passo 1, imagem 1 %32
    • Rinse the disc with water and wipe clean to remove any dust or dirt.
  2. How to Repair a Scratched CD: passo 2, imagem 1 %32 How to Repair a Scratched CD: passo 2, imagem 2 %32 How to Repair a Scratched CD: passo 2, imagem 3 %32
    • Apply a rubbing compound, moving from the center of the disc outwards.
    • Use enough force to create a mirror polished surface when rubbing compound application is complete.
    • We found that applying the rubbing compound for at least 30 seconds to 1 minute is sufficient.
  3. How to Repair a Scratched CD: passo 3, imagem 1 %32
    • Let the CD sit for 5 minutes.
  4. How to Repair a Scratched CD: passo 4, imagem 1 %32 How to Repair a Scratched CD: passo 4, imagem 2 %32
    • Wipe the CD clean with a new rag, removing any excess compound.
  5. How to Repair a Scratched CD: passo 5, imagem 1 %32 How to Repair a Scratched CD: passo 5, imagem 2 %32 How to Repair a Scratched CD: passo 5, imagem 3 %32
    • Apply a thin coat of car wax directly to the CD, using a circular application method.
    • Apply in either small circular motions or large motions that follow the circumference of the disc.
  6. How to Repair a Scratched CD: passo 6, imagem 1 %32 How to Repair a Scratched CD: passo 6, imagem 2 %32
    • Wipe the CD clean, removing any excess wax.
Conclusão
Congratulations! You have successfully repaired the scratched CD!
7 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 31
Últimos 30 dias: 173
Duração total: 13,018
