Ir para o conteúdo principal
How to Repair a Round Head Ratchet
O que você precisa
  1. How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: passo 1, imagem 1 %32 How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: passo 1, imagem 2 %32 How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: passo 1, imagem 3 %32
    • Remove the direction selector dial by turning it counterclockwise with a T15 screwdriver.
  2. How to Repair a Round Head Ratchet: passo 2, imagem 1 %32 How to Repair a Round Head Ratchet: passo 2, imagem 2 %32 How to Repair a Round Head Ratchet: passo 2, imagem 3 %32
    • Lift up on the direction selector dial to remove it.
    • Be careful to keep the heart spring in place during removal.
  3. How to Repair a Round Head Ratchet: passo 3, imagem 1 %32 How to Repair a Round Head Ratchet: passo 3, imagem 2 %32 How to Repair a Round Head Ratchet: passo 3, imagem 3 %32
    • Lift up on the heart spring to remove it.
  4. How to Repair a Round Head Ratchet: passo 4, imagem 1 %32 How to Repair a Round Head Ratchet: passo 4, imagem 2 %32 How to Repair a Round Head Ratchet: passo 4, imagem 3 %32
    • Remove the pawl and anvil by sliding them out of the ratchet handle.
  5. How to Repair a Round Head Ratchet: passo 5, imagem 1 %32
    • Clean all the old grease and dirt off the parts with a rag.
  6. How to Repair a Round Head Ratchet: passo 6, imagem 1 %32 How to Repair a Round Head Ratchet: passo 6, imagem 2 %32
    • Lubricate the pawl and the teeth in the head of the ratchet handle with a light coat of multi-purpose grease.
  7. How to Repair a Round Head Ratchet: passo 7, imagem 1 %32 How to Repair a Round Head Ratchet: passo 7, imagem 2 %32 How to Repair a Round Head Ratchet: passo 7, imagem 3 %32
    • Reinstall the anvil and pawl by sliding them into the ratchet handle.
  8. How to Repair a Round Head Ratchet: passo 8, imagem 1 %32 How to Repair a Round Head Ratchet: passo 8, imagem 2 %32 How to Repair a Round Head Ratchet: passo 8, imagem 3 %32
    • Reinstall the heart spring by sliding the end of the spring into the hole in the pawl.
  9. How to Repair a Round Head Ratchet: passo 9, imagem 1 %32 How to Repair a Round Head Ratchet: passo 9, imagem 2 %32 How to Repair a Round Head Ratchet: passo 9, imagem 3 %32
    • Reinstall the direction selector dial, being careful to place the stud on the dial within the loop of the heart spring.
  10. How to Repair a Round Head Ratchet: passo 10, imagem 1 %32 How to Repair a Round Head Ratchet: passo 10, imagem 2 %32 How to Repair a Round Head Ratchet: passo 10, imagem 3 %32
    • Reinstall the direction selector dial screw and tighten in a clockwise direction with a T15 screwdriver.
Linha de Chegada
Lucas
Membro desde: 10/08/21
229 Reputação
Autoria de 1 guia
2 comentários
Very clear and accurate, especially for the spring shape and its positioning in installation, which helped me to fix the problem with it.
Jason Zou - Responder
Perfect pictures and descriptions! My wrench is working again! Thanks!!!
John B. - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 43
Últimos 30 dias: 180
Duração total: 4,532
