Ir para o conteúdo principal
How to Repair a Ripped Lunch Bag Handle
O que você precisa
  1. How to Repair a Ripped Lunch Bag Handle, How to Repair a Ripped Lunch Bag Handle: passo 1, imagem 1 %32 How to Repair a Ripped Lunch Bag Handle, How to Repair a Ripped Lunch Bag Handle: passo 1, imagem 2 %32
    • Find colored thread to match the color of the lunch bag and a needle.
  2. How to Repair a Ripped Lunch Bag Handle: passo 2, imagem 1 %32 How to Repair a Ripped Lunch Bag Handle: passo 2, imagem 2 %32 How to Repair a Ripped Lunch Bag Handle: passo 2, imagem 3 %32
    • Gather thread that is 3 to 4 times the length of the part that needs to be sewn. Measure 18 inches of thread and double it.
    • Cut the thread to match the length of the ruler.
  3. How to Repair a Ripped Lunch Bag Handle: passo 3, imagem 1 %32 How to Repair a Ripped Lunch Bag Handle: passo 3, imagem 2 %32 How to Repair a Ripped Lunch Bag Handle: passo 3, imagem 3 %32
    • Loop one end of the thread through needle.
    • Wet the end of the thread if needed to make it easier to thread.
    • Move the needle to the middle of the thread to have even amounts of thread on each side.
  4. How to Repair a Ripped Lunch Bag Handle: passo 4, imagem 1 %32 How to Repair a Ripped Lunch Bag Handle: passo 4, imagem 2 %32 How to Repair a Ripped Lunch Bag Handle: passo 4, imagem 3 %32
    • Tie knot at the end of string and repeat 3x. Try to place all knots in the same place.
    • This will make the knot larger, so the thread stays in place on the lunchbox and does not pull through.
  5. How to Repair a Ripped Lunch Bag Handle: passo 5, imagem 1 %32 How to Repair a Ripped Lunch Bag Handle: passo 5, imagem 2 %32 How to Repair a Ripped Lunch Bag Handle: passo 5, imagem 3 %32
    • Thread the needle through the lunchbox and handle. Pull all the way through, until the knot stops. Start on the inside, so the knot is not visible at the end. Stick the needle the opposite direction, about a ¼” away from the first stitch. Leave room between your first and second stitch.
  6. How to Repair a Ripped Lunch Bag Handle: passo 6, imagem 1 %32 How to Repair a Ripped Lunch Bag Handle: passo 6, imagem 2 %32 How to Repair a Ripped Lunch Bag Handle: passo 6, imagem 3 %32
    • Thread the needle back through the lunchbox and handle in the space between your first and second stitch.
    • Continue to stitch every other space, until you have sewed the handle back in place.
  7. How to Repair a Ripped Lunch Bag Handle: passo 7, imagem 1 %32 How to Repair a Ripped Lunch Bag Handle: passo 7, imagem 2 %32 How to Repair a Ripped Lunch Bag Handle: passo 7, imagem 3 %32
    • To end the last stitch, thread the needle between the lunchbox and thread of your last stitch. Rather than pulling the thread completely through, thread the needle back through the excess thread to make a knot.
    • You can continue looping the needle about the thread to make the knot extra secure.
  8. How to Repair a Ripped Lunch Bag Handle: passo 8, imagem 1 %32 How to Repair a Ripped Lunch Bag Handle: passo 8, imagem 2 %32 How to Repair a Ripped Lunch Bag Handle: passo 8, imagem 3 %32
    • Trim the excess thread as short as possible to make the stitches look clean and to avoid snagging. Your bag should now be good as new!
Conclusão
Now your lunch bag should be good as new. There's no reason to throw a perfectly good lunch bag away when there's such a simple fix. Happy lunching!
Uma outra pessoa concluiu este guia.
Erica Lee
Membro desde: 10/26/18
169 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S1-G5, Bender Fall 2018 Membro de UC Davis, Team S1-G5, Bender Fall 2018
UCD-BENDER-F18S1G5
3 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 2,478
