Introdução
This fix will restore your fan's original power and quiet operation. This fix does not require new parts, but does require a #1 Phillips head screwdriver, an 8mm wrench or socket, and a medium or low viscosity lubricant.
O que você precisa
Loosen the 4 phillips screws around the rim and remove the front of the cage
Carefully pass the motor through the opening at the back of the cage.
Using an 8mm wrench and phillips screwdriver, remove the magnet mounts from the body of the motor.
The magnet will slide out of the motor . Inspect the magnet and motor for anything that may cause a hang-up.
To reassemble your device, follow these steps in reverse order.
5 outras pessoas executaram este guia.
4 comentários
What are the chances the exact fan that I need to repair would be here? I'm about to put it back together… Let's see if it worked! 9/3/19, 10:45 pm.
OK. It's back together but the fan doesn't spin. I feel the motor doing… Something. It vibrates softly. So, now to figure out why it's not spinning.
Mine did the same
hello…my fan wouldn't work until I tilt the head upwards..what could be wrong pls???
