Ir para o conteúdo principal
How to Repair a Portable Fan
O que você precisa
  1. How to Repair a Portable Fan, How to Repair a Portable Fan: passo 1, imagem 1 %32 How to Repair a Portable Fan, How to Repair a Portable Fan: passo 1, imagem 2 %32
    • Unplug the power cord before beginning.
    • Loosen the 4 phillips screws around the rim and remove the front of the cage
  2. How to Repair a Portable Fan: passo 2, imagem 1 %32
    • Remove the fan blade by loosening the screw on the shaft while pulling up.
    • The screw does not need to be fully removed before the blade will slide free.
  3. How to Repair a Portable Fan: passo 3, imagem 1 %32
    • Remove the wiring cover located above the fan motor.
    • There are 2 more screws holding the back mounting plate and cage together. They will be removed in a later step
  4. How to Repair a Portable Fan: passo 4, imagem 1 %32
    • Remove the motor from the mounting plate by loosing the 2 smaller screws on the front.
  5. How to Repair a Portable Fan: passo 5, imagem 1 %32
    • Remove the final 2 screws holding the mounting plate to the cage.
  6. How to Repair a Portable Fan: passo 6, imagem 1 %32
    • Carefully pass the motor through the opening at the back of the cage.
  7. How to Repair a Portable Fan: passo 7, imagem 1 %32 How to Repair a Portable Fan: passo 7, imagem 2 %32
    • Using an 8mm wrench and phillips screwdriver, remove the magnet mounts from the body of the motor.
    • The magnet will slide out of the motor . Inspect the magnet and motor for anything that may cause a hang-up.
    • Do not over-tighten the magnet mounts during reassembly. Over-tightening may cause the motor to bind.
  8. How to Repair a Portable Fan: passo 8, imagem 1 %32 How to Repair a Portable Fan: passo 8, imagem 2 %32
    • Clean and lubricate the magnet shaft and mounting brackets
    • Any medium or low viscosity lubricant will do.
Conclusão
To reassemble your device, follow these steps in reverse order.
6 outras pessoas executaram este guia.
Equipe
4Comentários do guia
What are the chances the exact fan that I need to repair would be here? I'm about to put it back together… Let's see if it worked! 9/3/19, 10:45 pm.
Clark Nova - Responder Compartilhar
OK. It's back together but the fan doesn't spin. I feel the motor doing… Something. It vibrates softly. So, now to figure out why it's not spinning.
Mine did the same
Bellatrix moore (Bellatrix) - Compartilhar
hello…my fan wouldn't work until I tilt the head upwards..what could be wrong pls???
adewale ogunbona - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 74
Últimos 30 dias: 246
Ao todo: 22,203
