Ir para o conteúdo principal
How to Repair a Patio Solar Light
O que você precisa
  1. How to Repair a Patio Solar Light, How to Repair a Patio Solar Light: passo 1, imagem 1 %32
    • Disassemble the circuit box using a Phillips screwdriver.
  2. How to Repair a Patio Solar Light: passo 2, imagem 1 %32
    • Using a multimeter, put the black wire in the COM port, and the red wire into the far right port. Set the switch to 20 volts DC.
  3. How to Repair a Patio Solar Light: passo 3, imagem 1 %32
    • Remove battery from the port.
    • Check both ends of the battery with the multimeter.
    • The red prong touches the negative side, and the black prong touches the positive side of the battery.
  4. How to Repair a Patio Solar Light: passo 4, imagem 1 %32
    • Ensure that the multimeter screen shows a number that matches or is greater than the voltage of the battery. If not, replace the battery.
    • Check the circuit board for detached, or loosely connected wires.
  5. How to Repair a Patio Solar Light: passo 5, imagem 1 %32 How to Repair a Patio Solar Light: passo 5, imagem 2 %32 How to Repair a Patio Solar Light: passo 5, imagem 3 %32
    • Use a soldering iron at 400 Celsius to melt your soldering wire. Gather a droplet on the tip of the soldering iron, and use the drop to reattach the disconnected wire back onto the circuit board.
    • CAUTION: Don't handle metal parts of the soldering iron without proper gloves and protection.
  6. How to Repair a Patio Solar Light: passo 6, imagem 1 %32
    • Turn your solar light back on before reassembling to test if it’s working properly.
    • When the light turns on, reassemble your solar light.
Conclusão
Miguel Antonio Gonzales
Membro desde: 02/20/24
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 23
Duração total: 73
