Introdução
Over time, snow globes can loosen or completely separate from their base. Some snow globes are irreplaceable; they could be limited edition, or simply have sentimental value. Buying a snow globe can also be quite expensive. Therefore, this beginner-friendly guide can help people fix their loose snow globe base using simple tools without any past repair experience.
O que você precisa
Place your snow globe in a heat-resistant bowl.
Remove the snow globe from the bowl and twist the snow globe counterclockwise from its base to separate the base from the globe.
If the globe is not easily separating from the base, place it back in the boiling water for one more minute and then try again. Repeat as many times as necessary.
Your snow globe's base should be sturdy again!
