Ir para o conteúdo principal
How to Repair a Loose Rear Bicycle Wheel
O que você precisa
  1. How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: passo 1, imagem 1 %32 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: passo 1, imagem 2 %32 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: passo 1, imagem 3 %32
    • Loosen the rear axle.
    • Turn the bike around, and loosen the brake arm.
  2. How to Repair a Loose Rear Bicycle Wheel: passo 2, imagem 1 %32 How to Repair a Loose Rear Bicycle Wheel: passo 2, imagem 2 %32
    • Take the chain off the gear and take out the wheel.
  3. How to Repair a Loose Rear Bicycle Wheel: passo 3, imagem 1 %32 How to Repair a Loose Rear Bicycle Wheel: passo 3, imagem 2 %32
    • Assess damage of the dropout and wheel.
  4. How to Repair a Loose Rear Bicycle Wheel: passo 4, imagem 1 %32 How to Repair a Loose Rear Bicycle Wheel: passo 4, imagem 2 %32
    • Properly set the wheel back into dropout and put the chain back on the gear.
  5. How to Repair a Loose Rear Bicycle Wheel: passo 5, imagem 1 %32 How to Repair a Loose Rear Bicycle Wheel: passo 5, imagem 2 %32
    • Pull on the wheel so that the chain is tight, while tightening the rear axle just enough to hold it in place.
  6. How to Repair a Loose Rear Bicycle Wheel: passo 6, imagem 1 %32 How to Repair a Loose Rear Bicycle Wheel: passo 6, imagem 2 %32 How to Repair a Loose Rear Bicycle Wheel: passo 6, imagem 3 %32
    • Check for misalignment or frame rubbing by pedaling without resistance.
  7. How to Repair a Loose Rear Bicycle Wheel: passo 7, imagem 1 %32 How to Repair a Loose Rear Bicycle Wheel: passo 7, imagem 2 %32 How to Repair a Loose Rear Bicycle Wheel: passo 7, imagem 3 %32
    • Fully tighten the axle.
    • Turn the bike around.
    • Reattach the brake arm.
Conclusão
Lily Suggs
Membro desde: 01/31/23
145 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-8, Andersen Winter 2023 Membro de UC Davis, Team 4-8, Andersen Winter 2023
UCD-ANDERSEN-W23S4G8
Membros da 3
1 Guia de autoria
Um comentário
Axle alignment is crooked, which can cause wobbling. Loosen the axle nuts or quick-release skewer, align the wheel, and tighten it securely.
Bruno John - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 86
Duração total: 690
