Ir para o conteúdo principal
How to Repair a Loose Modern Gooseneck Water Faucet
O que você precisa
  1. How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: passo 1, imagem 1 %32 How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: passo 1, imagem 2 %32 How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: passo 1, imagem 3 %32
    • On the bottom of the sink, you will see a water tank.
    • The next step is to close the vault. Slowly turn the vault to the right side.
    • You can see the vault is 90 degrees opposite to the direction when it was opened. That means it is now closed.
  2. How to Repair a Loose Modern Gooseneck Water Faucet: passo 2, imagem 1 %32 How to Repair a Loose Modern Gooseneck Water Faucet: passo 2, imagem 2 %32 How to Repair a Loose Modern Gooseneck Water Faucet: passo 2, imagem 3 %32
    • Check again by opening the tap to see if water is coming out of it or not.
    • Due to the loose neck, water is leaking from the sink.
    • The leakage can cause damage in the future, so, it is necessary to tighten the loose neck of the water dispenser.
  3. How to Repair a Loose Modern Gooseneck Water Faucet: passo 3, imagem 1 %32 How to Repair a Loose Modern Gooseneck Water Faucet: passo 3, imagem 2 %32 How to Repair a Loose Modern Gooseneck Water Faucet: passo 3, imagem 3 %32
    • Readjust the pipe to the way it was originally.
    • Make sure the realignment is properly done and that there are no gaps in it.
    • After, check the realignment from all sides so there are no places from where it can leak.
  4. How to Repair a Loose Modern Gooseneck Water Faucet: passo 4, imagem 1 %32 How to Repair a Loose Modern Gooseneck Water Faucet: passo 4, imagem 2 %32 How to Repair a Loose Modern Gooseneck Water Faucet: passo 4, imagem 3 %32
    • Use a wrench to adjust and tighten the screw on the right side to secure it in place.
Conclusão
Uma outra pessoa concluiu este guia.
kanishq viradiya
Membro desde: 03/11/24
121 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 213
