Ir para o conteúdo principal
How to Repair a Locket Hinge
O que você precisa
  1. How to Repair a Locket Hinge, How to Repair a Locket Hinge: passo 1, imagem 1 %32 How to Repair a Locket Hinge, How to Repair a Locket Hinge: passo 1, imagem 2 %32 How to Repair a Locket Hinge, How to Repair a Locket Hinge: passo 1, imagem 3 %32
    • Use pliers to carefully bend the damaged hinge back into place.
    • You want the hinge to be rounded and hollow, like a straw.
    • Test the hinge with some wire. If you can easily thread the wire through, then you can move on to Step 2. If not, keep bending.
  2. How to Repair a Locket Hinge: passo 2, imagem 1 %32 How to Repair a Locket Hinge: passo 2, imagem 2 %32 How to Repair a Locket Hinge: passo 2, imagem 3 %32
    • Hold both ends of the wire.
    • Place the middle of the wire against a hard edge. Hold the wire so that it is perpendicular to the edge.
    • Straighten the wire by pulling it against the edge.
  3. How to Repair a Locket Hinge: passo 3, imagem 1 %32 How to Repair a Locket Hinge: passo 3, imagem 2 %32
    • Bend the wire to match the contours of your locket.
    • If your locket is rounded, your wire will have to be curved. If your locket is straight, your wire will have to be straight.
  4. How to Repair a Locket Hinge: passo 4, imagem 1 %32 How to Repair a Locket Hinge: passo 4, imagem 2 %32
    • Cut the wire to a manageable length. We suggest the length of the hinges plus some excess.
  5. How to Repair a Locket Hinge: passo 5, imagem 1 %32 How to Repair a Locket Hinge: passo 5, imagem 2 %32 How to Repair a Locket Hinge: passo 5, imagem 3 %32
    • Match and align the front and back of the locket.
    • The holes of the hinge must be aligned, making a tunnel for the wire.
    • Line up the curved wire to match the locket shape.
    • Feed the wire through the hole of the hinge.
  6. How to Repair a Locket Hinge: passo 6, imagem 1 %32 How to Repair a Locket Hinge: passo 6, imagem 2 %32 How to Repair a Locket Hinge: passo 6, imagem 3 %32
    • Hold the locket closed.
    • Glue the top of the hinge.
    • Glue the bottom of the hinge.
    • Do not glue the center of the hinge.
  7. How to Repair a Locket Hinge: passo 7, imagem 1 %32 How to Repair a Locket Hinge: passo 7, imagem 2 %32
    • Hold the locket closed and hammer the side with the hinge and wire.
    • Tap firmly along the hinge and wire to secure.
  8. How to Repair a Locket Hinge: passo 8, imagem 1 %32 How to Repair a Locket Hinge: passo 8, imagem 2 %32
    • Cut the excess wire.
  9. How to Repair a Locket Hinge: passo 9, imagem 1 %32 How to Repair a Locket Hinge: passo 9, imagem 2 %32
    • The final product, the locket hinge is fixed and the locket can be used.
Linha de Chegada
Daisy J Williams
Membro desde: 01/31/24
169 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-3, Andersen Winter 2024 Membro de UC Davis, Team 4-3, Andersen Winter 2024
UCD-ANDERSEN-W24S4G3
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 23
Duração total: 127
