Introdução
Individuals often find themselves in a complex situation when dealing with chains. To open a knotted chain is another challenge in itself. If the chain is delicate in nature, it becomes riskier to untangle the knot. Attempting to open the knot can make it much tighter or break the chain entirely. However, with the help of the right tools and techniques, you can unknot your tangled chain within minutes.
O que você precisa
Find a flat surface.
Remove all clutter from your workspace to ensure you can access the chain easily.
Gently draw the toothpicks from one another to open and release the tight knot.
When you get an opening in the knot using the toothpicks, take it apart by pulling each separated strand through the knot to fully open it.
Then slowly pull apart the loosened knot to separate the chain strands.
