Ir para o conteúdo principal
How to Repair a Jammed Nozzle on a Perfume Bottle
O que você precisa
  1. How to Repair a Jammed Nozzle on a Perfume Bottle, How to Repair a Jammed Nozzle on a Perfume Bottle: passo 1, imagem 1 %32 How to Repair a Jammed Nozzle on a Perfume Bottle, How to Repair a Jammed Nozzle on a Perfume Bottle: passo 1, imagem 2 %32
    • Remove the nozzle from the bottle by taking the pliers and unscrewing the nozzle counterclockwise.
    • If the bottle is made from glass, untwist the nozzle from the bottle gently and slowly as much as possible to prevent the bottle from being damaged.
  2. How to Repair a Jammed Nozzle on a Perfume Bottle: passo 2, imagem 1 %32 How to Repair a Jammed Nozzle on a Perfume Bottle: passo 2, imagem 2 %32
    • Using your hand, gently pull out the tube so that the metal ball is exposed.
  3. How to Repair a Jammed Nozzle on a Perfume Bottle: passo 3, imagem 1 %32 How to Repair a Jammed Nozzle on a Perfume Bottle: passo 3, imagem 2 %32
    • Insert a sewing needle into the opening to adjust the metal ball that is stuck in the spring.
    • The reason why the nozzle of the perfume bottom is jammed is because the metal ball is stuck in the spring. This prevents the pump from retracting. The metal ball is supposed to be directly at the bottom of the spring which allows the pump to retract and the product to protrude out of the bottle when you press down on the nozzle.
  4. How to Repair a Jammed Nozzle on a Perfume Bottle: passo 4, imagem 1 %32 How to Repair a Jammed Nozzle on a Perfume Bottle: passo 4, imagem 2 %32
    • Using your hands, insert the tube back into the opening.
  5. How to Repair a Jammed Nozzle on a Perfume Bottle: passo 5, imagem 1 %32 How to Repair a Jammed Nozzle on a Perfume Bottle: passo 5, imagem 2 %32
    • Insert the sewing needle into the small opening to make sure that there is no clogging within the opening.
  6. How to Repair a Jammed Nozzle on a Perfume Bottle: passo 6, imagem 1 %32
    • Using the pliers, gently twist the jammed nozzle in a clockwise motion until the pump pops up.
  7. How to Repair a Jammed Nozzle on a Perfume Bottle: passo 7, imagem 1 %32
    • Using your hands, screw the nozzle back on to the bottle in a clockwise direction.
  8. How to Repair a Jammed Nozzle on a Perfume Bottle: passo 8, imagem 1 %32
    • Test the newly unjammed nozzle to see if the product projects out effectively.
Conclusão
To reassemble the perfume bottle, follow these instructions in reverse order.
6 outras pessoas executaram este guia.
Tiera Forde
Membro desde: 01/20/19
359 Reputação
Autoria de 1 guia
Equipe
5 comentários
complimenti, bell'articolo!
fabriziostar - Responder
This guide is stupid. BEFORE DOING THIS expose the nozzle and insert a sewing needle directly without removing the entire gasket. Don't cause unnecessary damage as most bottles have crimpted gaskets and are irremovable.
Nelson Bankowitz - Responder
hey stupid dont talk $@$* and do a video. I need to see it,
watchyourtyping -
Thank you so much!
Shadeka - Responder
Thanks now a needle is stuck in the tube
Jake Evens - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 232
Últimos 7 dias: 1,515
Últimos 30 dias: 7,446
Duração total: 250,220
