Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Do you have a pair of shoes or just one shoe with a hole on the shoe sole? With this guide, you will be able to repair the hole and reuse the shoe rather than buying a new pair.
O que você precisa
Clean the outsole with a wet paper towel.
Clean and dry the outsole with a paper towel before starting.
Now you can walk again!
30 outras pessoas executaram este guia.
10 comentários
Excellent - thank you
I wonder if there is any tip for a sole that has a hole all the way through. I tried something similar like this guid but it was quickly worn out. Maybe if I reinforce with duct tape and build the hole up from inside out, then make it a 2 step progress and do the outside first. Let dry for 2 days and then approach the same from the inside. Hmm such a shame certain brands have weak soles
Buen dia voy a seguir su recomendacion para reparar mis deportivo GRACIAS
