Introdução
If your floatie is slowly deflating then you probably punctured it. This guide will help you repair the punctured area and get you back in the water.
Before using this guide, check the valve stem to insure it is securely closed and not the cause of the inflating. If it is not the case then proceed with this guide.
Step 4 requires you to use scissors so please be cautious when cutting the waterproof tape.
O que você precisa
If the punctured area is not obvious:
Spritz soapy water over different areas of the inflated floatie and press down on the floatie until you see air bubbles.
Enjoy your renewed floatie!
3 outras pessoas executaram este guia.
