Ir para o conteúdo principal
How to Repair a Hole in an Inflatable Floatie
O que você precisa
  1. How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: passo 1, imagem 1 %32 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: passo 1, imagem 2 %32 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: passo 1, imagem 3 %32
    • If the punctured area is not obvious:
    • Spritz soapy water over different areas of the inflated floatie and press down on the floatie until you see air bubbles.
  2. How to Repair a Hole in an Inflatable Floatie: passo 2, imagem 1 %32 How to Repair a Hole in an Inflatable Floatie: passo 2, imagem 2 %32
    • Deflate the floatie by pinching the base of the valve stem and pressing down on the floatie to let the air out.
  3. How to Repair a Hole in an Inflatable Floatie: passo 3, imagem 1 %32 How to Repair a Hole in an Inflatable Floatie: passo 3, imagem 2 %32 How to Repair a Hole in an Inflatable Floatie: passo 3, imagem 3 %32
    • Clean the punctured area with alcohol wipes in order to help the waterproof tape adhere better.
    • Wait for the alcohol to completely dry.
    • If you do not have alcohol wipes available feel free to use soap, water and a towel. Then let the area dry completely.
  4. How to Repair a Hole in an Inflatable Floatie: passo 4, imagem 1 %32 How to Repair a Hole in an Inflatable Floatie: passo 4, imagem 2 %32 How to Repair a Hole in an Inflatable Floatie: passo 4, imagem 3 %32
    • Cut the waterproof tape two centimeters wider than the punctured area.
    • You can cut the waterproof tape in a circle or square; whichever you prefer.
  5. How to Repair a Hole in an Inflatable Floatie: passo 5, imagem 1 %32 How to Repair a Hole in an Inflatable Floatie: passo 5, imagem 2 %32 How to Repair a Hole in an Inflatable Floatie: passo 5, imagem 3 %32
    • Peel off the backing of the waterproof tape and center it over the punctured area.
    • Make sure the area is flat that way the waterproof tape will have less air bubbles when applied.
  6. How to Repair a Hole in an Inflatable Floatie: passo 6, imagem 1 %32 How to Repair a Hole in an Inflatable Floatie: passo 6, imagem 2 %32
    • Press down firmly on the patch making sure no air bubbles are visible.
    • Leave it for about 30 minutes.
    • Inflate your floatie and enjoy the water!
Conclusão
Enjoy your renewed floatie!
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 161
