Ir para o conteúdo principal
How to Repair a Hole in an Air Mattress
O que você precisa
  1. How to Repair a Hole in an Air Mattress, How to Repair a Hole in an Air Mattress: passo 1, imagem 1 %32
    • Inflate the air mattress fully using either a manual pump (pictured) or an electric pump.
    • An electric pump will save you time and energy so if you have that option definitely choose the electric pump, but know that means you need access to a plug.
  2. How to Repair a Hole in an Air Mattress: passo 2, imagem 1 %32
    • Identify the location of the hole.
    • Some techniques to locate holes are listening for air escaping or using soapy water.
  3. How to Repair a Hole in an Air Mattress: passo 3, imagem 1 %32
    • Clean around the hole where you plan to put the patch.
    • Use water and allow to air dry.
    • This will ensure a clean surface to attach the adhesive.
  4. How to Repair a Hole in an Air Mattress: passo 4, imagem 1 %32 How to Repair a Hole in an Air Mattress: passo 4, imagem 2 %32
    • Apply flexible adhesive made for vinyl where the patch is intended.
    • Use a brush or towel to spread adhesive to form an even layer.
  5. How to Repair a Hole in an Air Mattress: passo 5, imagem 1 %32 How to Repair a Hole in an Air Mattress: passo 5, imagem 2 %32
    • Apply a piece of vinyl patch on top of the adhesive to cover the hole.
    • Smooth out patches to ensure there are no bumps or bubbles.
    • You can smooth out bubbles with your fingers or use a plastic card.
  6. How to Repair a Hole in an Air Mattress: passo 6, imagem 1 %32
    • Allow the adhesive to fully dry per adhesive instructions before using the air mattress.
    • Enjoy your fixed air mattress!
Conclusão
To fill any other holes, repeat the same steps as many times as necessary.
Senia
Membro desde: 02/20/24
133 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 41
Ao todo: 539
