Ir para o conteúdo principal
How to Repair a Hole in a Duvet Insert
O que você precisa
  1. How to Repair a Hole in a Duvet Insert, How to Repair a Hole in a Duvet Insert: passo 1, imagem 1 %32
    • Remove the duvet cover from the insert and locate the hole.
  2. How to Repair a Hole in a Duvet Insert: passo 2, imagem 1 %32
    • Cut a piece of scrap fabric slightly larger than the hole.
  3. How to Repair a Hole in a Duvet Insert: passo 3, imagem 1 %32
    • Insert the fabric inside the hole, making sure the fabric covers the entirety of the opening.
  4. How to Repair a Hole in a Duvet Insert: passo 4, imagem 1 %32
    • Carefully pin the patch in place, ensuring the entire opening is covered and secure.
  5. How to Repair a Hole in a Duvet Insert: passo 5, imagem 1 %32
    • Insert thread in the needle hole and tie a slip knot at the end of the thread.
    • Keep extra thread pulled through the needle to prevent it from unthreading. If it does, re-thread and continue.
  6. How to Repair a Hole in a Duvet Insert: passo 6, imagem 1 %32 How to Repair a Hole in a Duvet Insert: passo 6, imagem 2 %32 How to Repair a Hole in a Duvet Insert: passo 6, imagem 3 %32
    • Insert the needle in one of the corners of your patch, being sure to pierce through both the duvet insert and patch.
    • Continue stitching around the perimeter of the patch with stitches around 1/4 of an inch long until you have reached your previous starting point.
  7. How to Repair a Hole in a Duvet Insert: passo 7, imagem 1 %32 How to Repair a Hole in a Duvet Insert: passo 7, imagem 2 %32
    • Sew around the hole's edges to secure the duvet insert into the patch to prevent future tearing.
  8. How to Repair a Hole in a Duvet Insert: passo 8, imagem 1 %32 How to Repair a Hole in a Duvet Insert: passo 8, imagem 2 %32 How to Repair a Hole in a Duvet Insert: passo 8, imagem 3 %32
    • Once finished, tie 1-2 knots and cut the thread off.
    • Make sure to leave 1/4 inch between the cut and the knot to prevent the knot from coming undone.
Linha de Chegada
Equipe
UC Davis, Team 3-3, Vidal-Chiesa Fall 2024 Membro de UC Davis, Team 3-3, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G3
3 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 29
Ao todo: 250
