Ir para o conteúdo principal
How to Repair a Frayed Headphone Cable
O que você precisa
  1. How to Repair a Frayed Headphone Cable, How to Repair a Frayed Headphone Cable: passo 1, imagem 1 %32 How to Repair a Frayed Headphone Cable, How to Repair a Frayed Headphone Cable: passo 1, imagem 2 %32
    • Cut above the frayed portion of the cable using wire cutters.
    • Using the wire cutters, strip away approximately one inch of wire coating.
    • Use caution to avoid cutting too far into the wire.
  2. How to Repair a Frayed Headphone Cable: passo 2, imagem 1 %32 How to Repair a Frayed Headphone Cable: passo 2, imagem 2 %32
    • After stripping the wire, four wires should be exposed. The wires should be three different colors.
    • Red: Right channel
    • Gold/copper: Ground
    • Blue/green: Left channel
    • Twist the two ground wires together.
  3. How to Repair a Frayed Headphone Cable: passo 3, imagem 1 %32 How to Repair a Frayed Headphone Cable: passo 3, imagem 2 %32
    • Unscrew the plug housing.
    • Thread the wire through the plug housing.
  4. How to Repair a Frayed Headphone Cable: passo 4, imagem 1 %32
    • Remove the enamel from the red and blue wires with a wire stripper.
  5. How to Repair a Frayed Headphone Cable: passo 5, imagem 1 %32
    • With a soldering iron, apply a small amount of solder to the end of each wire.
    • This is especially important for the twisted ground wires; the solder should hold them together.
  6. How to Repair a Frayed Headphone Cable: passo 6, imagem 1 %32 How to Repair a Frayed Headphone Cable: passo 6, imagem 2 %32 How to Repair a Frayed Headphone Cable: passo 6, imagem 3 %32
    • Thread the wires through each hole and wrap them back over.
    • See the third picture for a diagram of where each wire goes.
    • Next, twist each wire with itself to secure it to the lead. This can be seen in the second picture.
  7. How to Repair a Frayed Headphone Cable: passo 7, imagem 1 %32 How to Repair a Frayed Headphone Cable: passo 7, imagem 2 %32
    • Solder over each lead's hole, connecting the wire to the lead.
    • Your solder joints should completely cover the hole and surround the wire.
    • After each wire is connected, use a drop of hot glue to secure the wires and prevent them from touching each other.
  8. How to Repair a Frayed Headphone Cable: passo 8, imagem 1 %32
    • Screw the housing back onto the jack and test your work.
    • If the sound turns on and off this is a connection error. To fix it, look at your solder joints and make sure the wires are fully connected to the leads. If not, apply more solder to the joints, covering the wire.
Linha de Chegada
36 outras pessoas executaram este guia.
Tyler
Membro desde: 02/24/15
836 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-2, Green Winter 2015 Membro de Cal Poly, Team 23-2, Green Winter 2015
CPSU-GREEN-W15S23G2
Membros da 4
Autoria de 16 guias
2 comentários
To me, the more difficult part in this job, is solder.... Now, If you are not sure, with where solder each wire, try with a tester in the continuity mode, and test between the each part of the tip and the three holes. Greetings!
Anderson Barreto - Responder
great instruction - any for repair of cable with microphone ? and even a flat cable ?
LiveVest - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 133
Últimos 30 dias: 634
Duração total: 113,016
