Ir para o conteúdo principal
How to Repair a Damaged Action Figure
O que você precisa
  1. How to Repair a Damaged Action Figure, How to Repair a Damaged Action Figure: passo 1, imagem 1 %32
    • Clean the figurine and wash your hands before starting.
  2. How to Repair a Damaged Action Figure: passo 2, imagem 1 %32
    • Identify the broken parts and apply a small drop of super glue on the area needing a fix.
    • CAUTION: AVOID DIRECT SKIN CONTACT WITH THE GLUE. Glue can cause skin irritation or burns.
  3. How to Repair a Damaged Action Figure: passo 3, imagem 1 %32 How to Repair a Damaged Action Figure: passo 3, imagem 2 %32
    • Press the two pieces together and make sure they match. Hold them together tightly for 2 minutes.
    • If any glue leaks outside when pressing, use an alcohol wipe to clean it.
  4. How to Repair a Damaged Action Figure: passo 4, imagem 1 %32
    • Let the glue settle and dry for a minimum of 1 hour.
  5. How to Repair a Damaged Action Figure: passo 5, imagem 1 %32
    • Use acrylic paint as necessary for patching chipped sections of the plastic.
  6. How to Repair a Damaged Action Figure: passo 6, imagem 1 %32
    • Allow the paint to fully dry before attempting to move or adjust the figurine.
    • You can use hair dryer to speed up the drying process.
Conclusão
Uma outra pessoa concluiu este guia.
Anabela Stewart
Membro desde: 01/31/23
142 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-8, Andersen Winter 2023 Membro de UC Davis, Team 3-8, Andersen Winter 2023
UCD-ANDERSEN-W23S3G8
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 91
Duração total: 1,715
