Ir para o conteúdo principal
How to Repair a Cracked Flower Pot
O que você precisa
  1. How to Repair a Cracked Flower Pot, How to Repair a Cracked Flower Pot: passo 1, imagem 1 %32 How to Repair a Cracked Flower Pot, How to Repair a Cracked Flower Pot: passo 1, imagem 2 %32
    • Remove any contents from the pot.
  2. How to Repair a Cracked Flower Pot: passo 2, imagem 1 %32
    • Apply craft adhesive along the broken portion of the pot.
    • Warning: your adhesive may be flammable. Carefully read the cautions listed on your adhesive before proceeding.
  3. How to Repair a Cracked Flower Pot: passo 3, imagem 1 %32 How to Repair a Cracked Flower Pot: passo 3, imagem 2 %32 How to Repair a Cracked Flower Pot: passo 3, imagem 3 %32
    • Begin to apply glue onto the broken pieces.
    • Once you apply glue to a piece, attach it to the pot.
  4. How to Repair a Cracked Flower Pot: passo 4, imagem 1 %32 How to Repair a Cracked Flower Pot: passo 4, imagem 2 %32 How to Repair a Cracked Flower Pot: passo 4, imagem 3 %32
    • Scrape away the excess glue on both the outside and inside of the pot with scrap paper.
    • Make sure to do this before the glue dries completely.
  5. How to Repair a Cracked Flower Pot: passo 5, imagem 1 %32 How to Repair a Cracked Flower Pot: passo 5, imagem 2 %32
    • Use a shoelace or twine to tightly hold the pot together while it dries.
    • Depending on your glue, drying time may take up to 24-72 hours.
  6. How to Repair a Cracked Flower Pot: passo 6, imagem 1 %32 How to Repair a Cracked Flower Pot: passo 6, imagem 2 %32 How to Repair a Cracked Flower Pot: passo 6, imagem 3 %32
    • Once your adhesive has finished drying, remove the shoelace or twine.
  7. How to Repair a Cracked Flower Pot: passo 7, imagem 1 %32 How to Repair a Cracked Flower Pot: passo 7, imagem 2 %32
    • Return your plant to its pot.
Conclusão
Now your flower pot is fixed and ready to be used!
Uma outra pessoa concluiu este guia.
Irene Amuyunzu
Membro desde: 10/26/18
148 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S1-G6, Bender Fall 2018 Membro de UC Davis, Team S1-G6, Bender Fall 2018
UCD-BENDER-F18S1G6
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 43
Duração total: 3,264
