Ir para o conteúdo principal
How to Repair a Crack on a Vittorazi Moster Exhaust
O que você precisa
  1. How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: passo 1, imagem 1 %32 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: passo 1, imagem 2 %32 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: passo 1, imagem 3 %32
    • Use a 10mm open wrench to lossen the three exhaust mounting points.
    • Locate the nuts that need to be adjusted and make sure you you have the proper tools, stated earlier to ensure they can loosen.
    • Once you have found the nuts, use your 10mm wrench to carefully unscrew and loosen the nuts.
    • This may take some extra force to loosen the nuts, and if this is case, keep in mind all safety precautions.
  2. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 5, imagem 1 %32 How to Repair a Crack on a Vittorazi Moster Exhaust: passo 5, imagem 2 %32
    • Remove with the 10mm wrench the two nuts in the exhaust base.
  3. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 6, imagem 1 %32
    • Remove the loosen mounts and take out the exhaust with it's base.
  4. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 7, imagem 1 %32
    • Clean the cracked area with alcohol and a rug.
  5. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 8, imagem 1 %32 How to Repair a Crack on a Vittorazi Moster Exhaust: passo 8, imagem 2 %32
    • Grind the cracked area with the grinder.
  6. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 9, imagem 1 %32 How to Repair a Crack on a Vittorazi Moster Exhaust: passo 9, imagem 2 %32
    • Weld the cracked area with the welder.
  7. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 10, imagem 1 %32 How to Repair a Crack on a Vittorazi Moster Exhaust: passo 10, imagem 2 %32
    • Grind the welded area with the grinder to smooth the area.
  8. How to Repair a Crack on a Vittorazi Moster Exhaust: passo 11, imagem 1 %32
    • Reinstall the exhaust to the motor by repeating 1-3 steps in reverse order.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 23
Duração total: 1,072
