Ir para o conteúdo principal
How to Repair a Christmas Tree Light Wire
O que você precisa
  1. How to Repair a Christmas Tree Light Wire, How to Repair a Christmas Tree Light Wire: passo 1, imagem 1 %32
    • Unplug the lighting.
  2. How to Repair a Christmas Tree Light Wire: passo 2, imagem 1 %32 How to Repair a Christmas Tree Light Wire: passo 2, imagem 2 %32
    • Using the wire strippers, split both wires apart approximately one inch.
  3. How to Repair a Christmas Tree Light Wire: passo 3, imagem 1 %32 How to Repair a Christmas Tree Light Wire: passo 3, imagem 2 %32
    • Using the wire strippers, strip about an inch of insulation off of each wire.
    • Use appropriate wire gauge when stripping. A good practice is to start with large gauge and work your way down.
  4. How to Repair a Christmas Tree Light Wire: passo 4, imagem 1 %32 How to Repair a Christmas Tree Light Wire: passo 4, imagem 2 %32
    • Twist all four copper strands.
    • This will make it easier to work with and help prevent fraying.
  5. How to Repair a Christmas Tree Light Wire: passo 5, imagem 1 %32
    • Insert the heat shrink tubing on the longer end of your wire.
    • Once the heat shrink is on your wire, slide it out of your way. We will address the heat shrink in Step 9.
  6. How to Repair a Christmas Tree Light Wire: passo 6, imagem 1 %32 How to Repair a Christmas Tree Light Wire: passo 6, imagem 2 %32 How to Repair a Christmas Tree Light Wire: passo 6, imagem 3 %32
    • Cross and twist the wires together to create a connection.
    • This helps the wires form a better connection when soldering together.
  7. How to Repair a Christmas Tree Light Wire: passo 7, imagem 1 %32 How to Repair a Christmas Tree Light Wire: passo 7, imagem 2 %32
    • Solder your wires together by applying heat to the bottom of your wires and solder to the top. The solder will melt onto the copper strands solidifying both wires together.
    • Burn and fire hazard. Take appropriate precautions and solder in a well-ventilated area.
    • Pre-heat soldering iron to 325 Fahrenheit.
  8. How to Repair a Christmas Tree Light Wire: passo 8, imagem 1 %32
    • Use electrical tape to wrap the soldered wires.
    • This will prevent both wires from contacting each other.
  9. How to Repair a Christmas Tree Light Wire: passo 9, imagem 1 %32
    • Slide the heat shrink over the soldered wires.
  10. How to Repair a Christmas Tree Light Wire: passo 10, imagem 1 %32
    • Use your heat source to apply heat to the heat shrink.
    • Apply heat from heat appliance half an inch away from heat shrink.
  11. How to Repair a Christmas Tree Light Wire: passo 11, imagem 1 %32 How to Repair a Christmas Tree Light Wire: passo 11, imagem 2 %32
    • Connect your Christmas tree plug into the outlet.
Conclusão
You've completed soldering and properly covered any exposed wires being worked on. Connect your cable to an electrical outlet; you're Christmas tree is ready to light once again.
1Comentário do guia
You can also offset the lengths of the twin wires so the joints aren't next to each other for more protection from a short.
pdb - Responder
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 75
Últimos 30 dias: 306
Ao todo: 1,795
