Ir para o conteúdo principal
How to Repair a Burnt Pan
O que você precisa
  1. How to Repair a Burnt Pan, How to Repair a Burnt Pan: passo 1, imagem 1 %32 How to Repair a Burnt Pan, How to Repair a Burnt Pan: passo 1, imagem 2 %32
    • Rinse the dirty pan with hot water.
  2. How to Repair a Burnt Pan: passo 2, imagem 1 %32 How to Repair a Burnt Pan: passo 2, imagem 2 %32
    • Grab a dishwasher tab and gently scrub the pan under warm water.
  3. How to Repair a Burnt Pan: passo 3, imagem 1 %32
    • Scrub until the food debris lifts.
    • The warm water will gradually dissolve the tab as you scrub and help the tablet keep its shape rather than crumble immediately between your fingers.
  4. How to Repair a Burnt Pan: passo 4, imagem 1 %32 How to Repair a Burnt Pan: passo 4, imagem 2 %32
    • Rinse the pan with hot water and drain.
  5. How to Repair a Burnt Pan: passo 5, imagem 1 %32
    • Use a sponge, brush, or scouring pad to scrub away the loosened burnt-on food.
  6. How to Repair a Burnt Pan: passo 6, imagem 1 %32 How to Repair a Burnt Pan: passo 6, imagem 2 %32
    • Repeat steps 4 & 5, if needed, for any stubborn spots.
  7. How to Repair a Burnt Pan: passo 7, imagem 1 %32 How to Repair a Burnt Pan: passo 7, imagem 2 %32
    • Before and after look of the pan.
Conclusão
As we all cook at home, there are times when we accidentally burn the pan, especially when using a stainless steel pan instead of a nonstick one, for instance, while frying an egg or making caramel. Most of us have tried various cleaning methods. Combining personal experience with online resources, this method has proven to be the most effective and cost-friendly.
Trinh Nguyen
Membro desde: 04/26/24
145 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-8, Whithaus Spring 2024 Membro de UC Davis, Team 2-8, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G8
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 32
Duração total: 147
