Ir para o conteúdo principal
How to Repair a Broken Playhouse Door
O que você precisa
  1. How to Repair a Broken Playhouse Door, How to Repair a Broken Playhouse Door: passo 1, imagem 1 %32
    • Label each piece of wood with a number.
    • The door in this guide has seven panels, so I'll be labeling them 1 through 7.
  2. How to Repair a Broken Playhouse Door: passo 2, imagem 1 %32 How to Repair a Broken Playhouse Door: passo 2, imagem 2 %32 How to Repair a Broken Playhouse Door: passo 2, imagem 3 %32
    • Use a Phillips screwdriver to remove all the screws so that each wood panel is separated.
  3. How to Repair a Broken Playhouse Door: passo 3, imagem 1 %32 How to Repair a Broken Playhouse Door: passo 3, imagem 2 %32
    • Gather all the individual wood panels and line them up in their numbered order so that the door looks complete.
  4. How to Repair a Broken Playhouse Door: passo 4, imagem 1 %32 How to Repair a Broken Playhouse Door: passo 4, imagem 2 %32
    • Apply wood glue to each panel of wood where it intersects with another piece.
    • You may want to keep a towel or napkin nearby to wipe off any excess glue.
  5. How to Repair a Broken Playhouse Door: passo 5, imagem 1 %32 How to Repair a Broken Playhouse Door: passo 5, imagem 2 %32
    • Attach clamps to the wood panels where the glue was applied. Place one clamp on each end.
    • It might be easiest to glue and clamp two wood panels together at a time and then attach all the pieces together once the glue dries.
    • Keep the clamps on the wood panels until the glue is completely dry. It takes about 24 hours for the glue to fully cure.
  6. How to Repair a Broken Playhouse Door: passo 6, imagem 1 %32 How to Repair a Broken Playhouse Door: passo 6, imagem 2 %32 How to Repair a Broken Playhouse Door: passo 6, imagem 3 %32
    • After removing the clamps, use the Phillips screwdriver to put the screws back in the same spots they were removed from.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 97
