Ir para o conteúdo principal
How to Repair a Broken Plant Stem
Visualizações: 38 mil
Visualizar Estatísticas:
Últimas 24 horas:
15
Últimos 7 dias:
92
Últimos 30 dias:
327
Ao todo:
38.392
Comentários: 2
2 guide comments.
Go to guide comments
Concluído: 2
2 pessoas marcaram este guia como "concluído". Será você o próximo?
Favorites: 0
Ninguém favoritou (e se inscreveu) neste guia como favorito. Você será o primeiro?
Tempo necessário: 10 - 15 minutos
Dificuldade: Fácil
Introdução
Ir para o passo 1 ↓
Use this guide to repair a broken plant stem. Maybe a windowsill got closed too fast, someone stepped without looking, or weather changes were too harsh. There are many reasons why plants get thrown out too early before they’re given the chance to be repaired. However, don't let a broken stem be one of those reasons. This quick and accessible guide will allow you to care for your broken plants without having to do hours of research beforehand.
Use this guide if the broken stem comes from a plant with roots. The repair process will take time and needs a lot of energy so having roots is necessary for soaking up nutrients from the soil.
Before starting, you'll need to know how long the stem has been broken for because time is of the essence. If the plant has been broken for too long, it is not receiving the nutrients it needs and will die if not repaired quickly.
O que você precisa
    1. How to Repair a Broken Plant Stem, How to Repair a Broken Plant Stem: passo 1, imagem 1 %32
      • Determine whether the stem is completely severed or still attached by some connective tissue.
      • If the stem is bent, but still attached, the connective tissue helps the regrowth process and you may proceed to the following steps.
      • If the stem is completely severed, the following steps will not work.
      Pergunte ao FixBot
      Comentar
    2. How to Repair a Broken Plant Stem: passo 2, imagem 1 %32
      • Place the support stick securely in the soil next to the broken stem.
      • Make sure the stick you choose is similar in size to the plant stem.
      Pergunte ao FixBot
      Comentar
    3. How to Repair a Broken Plant Stem: passo 3, imagem 1 %32
      • Gently position the stem upright along the stick.
      Pergunte ao FixBot
      Comentar
    4. How to Repair a Broken Plant Stem: passo 4, imagem 1 %32
      • Measure the garden tie tape around the stick and broken stem.
      • Cut tape to a desired length using scissors.
      • Twine or garden wire can be used as a replacement of graden tie tape.
      Pergunte ao FixBot
      Comentar
    5. How to Repair a Broken Plant Stem: passo 5, imagem 1 %32 How to Repair a Broken Plant Stem: passo 5, imagem 2 %32
      • Securely tie a double knot around the stem and the stick.
      • Make sure to keep the knot loose enough to leave room for air circulation and plant growth.
      Pergunte ao FixBot
      Comentar
    6. How to Repair a Broken Plant Stem: passo 6, imagem 1 %32
      • Remove or prune the dead leaves from the pot.
      • This will ensure that the nutrients goes to the recovering stem instead of the dead members.
      Pergunte ao FixBot
      Comentar
    7. How to Repair a Broken Plant Stem: passo 7, imagem 1 %32
      • Place the plant in extra nutrient filled soil for the plant to heal.
      Pergunte ao FixBot
      Comentar
    8. How to Repair a Broken Plant Stem: passo 8, imagem 1 %32
      • Continue to monitor the plant everyday.
      • Water the plant as needed.
      • Pay special attention to the broken area to make sure there is no mold development.
      Pergunte ao FixBot
      Comentar
Conclusão
Autor(a)
com
Zeeann McCarty
Membro desde: 02/03/23
205 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-5, Andersen Winter 2023 Membro de UC Davis, Team 3-5, Andersen Winter 2023
UCD-ANDERSEN-W23S3G5
2 Membros
Autoria de 12 guias
2Comentários do guia
Helllppp! Ma tige principale de ma philodendron burle Marx s’est cassée!😞
J’ai une superbe plante qui fait plein de bébés mais aujourd’hui je suis rentrée et la moitié de la tige principale s’est rompue au ras du sol!!!
Je l’ai remise droite avec un tuteur et arrosée..
Est-ce que j’ai des chances qu’elle se « « rattache » Où dois-je couper toutes les tiges pour en faire des boutures séparées ?
Merci de votre aide je suis trop déçue elle est superbe ..
Mylo - Responder Compartilhar
Hola, qué fué lo que hiciste?. Si sobrevivió?
El tallo principal de mi plata se rompió, lo puse en agua pero no sé si echara raíces o se perderá help
Kenneth González - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 15
Últimos 7 dias: 92
Últimos 30 dias: 327
Ao todo: 38,392
