Ir para o conteúdo principal
How to Repair a Broken Kitchen Faucet Pull-out Spray Head
O que você precisa
  1. How to Repair a Broken Kitchen Faucet Pull-out Spray Head, Kitchen Faucet Pull-out Spray Head: passo 1, imagem 1 %32 How to Repair a Broken Kitchen Faucet Pull-out Spray Head, Kitchen Faucet Pull-out Spray Head: passo 1, imagem 2 %32
    • Located underneath the sink is the water-control valve.
    • Shut off the water supply by turning the water-control valve.
    • Not all water control values are the same so some nozzles may vary.
  2. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: passo 2, imagem 1 %32 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: passo 2, imagem 2 %32 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: passo 2, imagem 3 %32
    • Pull on the kitchen spray head nozzle to reveal the connected hose.
    • Unscrew the kitchen faucet spray head nozzle counterclockwise off of the hose assembly.
  3. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: passo 3, imagem 1 %32 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: passo 3, imagem 2 %32
    • Remove the rubber gasket from the hose to reveal the c-clip.
    • Remove the c-clip that is located on the pull-out sprayer connection point with a small flat head screwdriver.
    • Do not discard the gasket. It can be reused unless damaged.
  4. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: passo 4, imagem 1 %32 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: passo 4, imagem 2 %32
    • Pull on the sink faucet spray head from above the sink to find the main hose connection point to the water line located underneath the sink.
    • Unscrew the hose from the main faucet’s water line connection point.
    • A wrench may be necessary in order to loosen the nut.
    • Remove the hose from the sink sprayer location.
    • Connect the new hose by pressing it into the connection point. Then screw hose back on clockwise.
    • A wrench may be necessary in order to secure the end of the hose to the nut.
  5. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: passo 5, imagem 1 %32
    • Apply plumber's tape to the male threads on the new sink sprayer head to avoid leakage.
Conclusão
Jodi Wright
Membro desde: 02/23/16
158 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 26-2, Rauch Spring 2016 Membro de Texas Tech, Team 26-2, Rauch Spring 2016
TTU-RAUCH-S16S26G2
2 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 14,076
