Ir para o conteúdo principal
How to Repair a Bent Liquid Eyeliner Applicator
O que você precisa
  1. How to Repair a Bent Liquid Eyeliner Applicator, How to Repair a Bent Liquid Eyeliner Applicator: passo 1, imagem 1 %32
    • Remove the cap of the eyeliner.
  2. How to Repair a Bent Liquid Eyeliner Applicator: passo 2, imagem 1 %32 How to Repair a Bent Liquid Eyeliner Applicator: passo 2, imagem 2 %32 How to Repair a Bent Liquid Eyeliner Applicator: passo 2, imagem 3 %32
    • Wrap the eyeliner applicator tightly with plastic wrap.
    • The plastic wrap should be just large enough to cover the applicator.
    • Smooth the bent bristles of the applicator in the same direction.
    • Smooth the excess plastic wrap along the body of the eyeliner.
  3. How to Repair a Bent Liquid Eyeliner Applicator: passo 3, imagem 1 %32
    • Secure the plastic wrap tightly with a rubber band.
    • The rubber band should circle the middle of the applicator.
    • Check to make sure there are no holes in the plastic wrap.
  4. How to Repair a Bent Liquid Eyeliner Applicator: passo 4, imagem 1 %32
    • Fill a pot with water.
    • The water level should be high enough to cover the tip of the eyeliner.
  5. How to Repair a Bent Liquid Eyeliner Applicator: passo 5, imagem 1 %32 How to Repair a Bent Liquid Eyeliner Applicator: passo 5, imagem 2 %32
    • Boil the water.
    • Turn off the heat once the water has reached a boil.
  6. How to Repair a Bent Liquid Eyeliner Applicator: passo 6, imagem 1 %32 How to Repair a Bent Liquid Eyeliner Applicator: passo 6, imagem 2 %32
    • Hold the eyeliner vertically above the pot of water. The applicator should be facing down.
    • Place the eyeliner applicator into the boiled water for 1 minute.
    • Do not submerge the eyeliner further than the applicator.
  7. How to Repair a Bent Liquid Eyeliner Applicator: passo 7, imagem 1 %32 How to Repair a Bent Liquid Eyeliner Applicator: passo 7, imagem 2 %32
    • Carefully remove the rubber band and the plastic wrap.
    • Great Job! Your eyeliner is ready to be used again.
Conclusão
This fix is a great alternative to throwing away eyeliner that still has plenty of pigment. You'll be saving money AND the environment. What could be better?
3 outras pessoas executaram este guia.
Tracy Sam
Membro desde: 10/26/18
226 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S2-G4, Bender Fall 2018 Membro de UC Davis, Team S2-G4, Bender Fall 2018
UCD-BENDER-F18S2G4
Membros da 2
1 Guia de autoria
Um comentário
Saved me from going to the store for the old lady to get a new one. Thanks a $@$* load!!!!
jeremy loughran - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 23
Últimos 30 dias: 94
Duração total: 11,876
