Ir para o conteúdo principal
How to Repair a Belt Loop on Dress Pants
O que você precisa
  1. How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: passo 1, imagem 1 %32 How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: passo 1, imagem 2 %32 How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: passo 1, imagem 3 %32
    • Thread the sewing machine with a thread that matches your pants.
    • Thread via your sewing machine instructions. They can be marked on your machine, or in a separate pamphlet.
  2. How to Repair a Belt Loop on Dress Pants: passo 2, imagem 1 %32 How to Repair a Belt Loop on Dress Pants: passo 2, imagem 2 %32 How to Repair a Belt Loop on Dress Pants: passo 2, imagem 3 %32
    • Remove the extension table from the sewing machine.
  3. How to Repair a Belt Loop on Dress Pants: passo 3, imagem 1 %32
    • Pin the belt loop seam side up so that the top of the loop is 1/4 inch above the seam.
  4. How to Repair a Belt Loop on Dress Pants: passo 4, imagem 1 %32 How to Repair a Belt Loop on Dress Pants: passo 4, imagem 2 %32 How to Repair a Belt Loop on Dress Pants: passo 4, imagem 3 %32
    • Sew using a straight stitch along the seam.
    • Use the reverse feature on the sewing machine to go over the stitches three times.
    • Once the sewing foot is down and the needle is in the fabric you can remove the pin.
  5. How to Repair a Belt Loop on Dress Pants: passo 5, imagem 1 %32 How to Repair a Belt Loop on Dress Pants: passo 5, imagem 2 %32 How to Repair a Belt Loop on Dress Pants: passo 5, imagem 3 %32
    • Remove the pants from the sewing machine by cutting the threads.
  6. How to Repair a Belt Loop on Dress Pants: passo 6, imagem 1 %32
    • Fold the interfacing over so that it is out of the way of the needle.
    • If the pants do not have interfacing, this step can be skipped.
  7. How to Repair a Belt Loop on Dress Pants: passo 7, imagem 1 %32 How to Repair a Belt Loop on Dress Pants: passo 7, imagem 2 %32
    • Sew the belt loop a 1/4 inch below the seam using a straight stitch.
    • Use the reverse feature to go over the stitches three times.
  8. How to Repair a Belt Loop on Dress Pants: passo 8, imagem 1 %32
  9. How to Repair a Belt Loop on Dress Pants: passo 9, imagem 1 %32
    • Fold the belt loop over.
  10. How to Repair a Belt Loop on Dress Pants: passo 10, imagem 1 %32 How to Repair a Belt Loop on Dress Pants: passo 10, imagem 2 %32 How to Repair a Belt Loop on Dress Pants: passo 10, imagem 3 %32
    • Trim the belt loop's excess length so that there is a 1/4 inch overlap.
  11. How to Repair a Belt Loop on Dress Pants: passo 11, imagem 1 %32
    • Pin the folded belt loop to the top of the waistband.
  12. How to Repair a Belt Loop on Dress Pants: passo 12, imagem 1 %32 How to Repair a Belt Loop on Dress Pants: passo 12, imagem 2 %32
    • Sew the top of the belt loop with an 1/8 inch seam allowance, using a straight stitch.
    • Use the reverse feature on the sewing machine and go over the stitches three times.
  13. How to Repair a Belt Loop on Dress Pants: passo 13, imagem 1 %32 How to Repair a Belt Loop on Dress Pants: passo 13, imagem 2 %32 How to Repair a Belt Loop on Dress Pants: passo 13, imagem 3 %32
  14. How to Repair a Belt Loop on Dress Pants: passo 14, imagem 1 %32
    • Trim any remaining threads.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 64
