Ir para o conteúdo principal
How to Repair a Bed Rail
O que você precisa
  1. How to Repair a Bed Rail, How to Repair a Bed Rail: passo 1, imagem 1 %32
    • Place an item(s) underneath the bed rail to support it. This can be bricks or books.
  2. How to Repair a Bed Rail: passo 2, imagem 1 %32
    • Measure the length of the slat, and mark the middle.
    • This is the position where you will place the wooden plank and hammer in the nails.
  3. How to Repair a Bed Rail: passo 3, imagem 1 %32 How to Repair a Bed Rail: passo 3, imagem 2 %32
    • Vertically place your pre-cut wooden plank under the slat that is detached.
  4. How to Repair a Bed Rail: passo 4, imagem 1 %32
    • Hammer the 50 mm nails down into the slat and into the wooden plank. You can use 2 or more to ensure the wooden plank is secure.
  5. How to Repair a Bed Rail: passo 5, imagem 1 %32
    • Afterwards, run the glue along the detached bed rail.
  6. How to Repair a Bed Rail: passo 6, imagem 1 %32
    • Reattach the bed rail and let the glue dry.
  7. How to Repair a Bed Rail: passo 7, imagem 1 %32
    • After the glue has dried, remove your supports.
Conclusão
Endiyah Franklin
Membro desde: 03/31/20
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 39
Duração total: 2,177
