Introdução
This guide will show the user how to take apart the junction box and clean any corrosion in your 2010-2014 Ford Mustang. If you have corrosion this can cause electrical problems.
O que você precisa
Pull hood release tab inside the car.
Using a 10 mm socket wrench, remove the mounting nut from bottom of junction box.
Slightly lift the junction box and then remove the final large connector on the bottom of the junction box.
Lift the junction box 90 degrees to unhook the junction box from the fender wall and then pull the junction box completely out.
10 outras pessoas executaram este guia.
9 comentários
Great job with this guide.
Fantastic, with good photos. My 2011 Mustang Tire Pressure Monitor system is putting up error message "Tire Pressure Sensor Fault" but the sending units in the wheels/tires are new and have been tested twice as working correctly and the TPMS system was reset, but after 30 minutes of driving the warning light flashes and the error message appears. Tire pressure is exactly what it is supposed to be. I asked the local Ford dealer what they charged to determine what is wrong with the system.......$200!.. No thanks. Then I found out the Smart Junction Box (AKA Body Control Module) is $432 from this dealer, but can be had new from other Ford dealers for as low as $290. However I strongly suspect that the only problem is a bad electrical connection, so I will follow this guide to clean the contacts and I bet that is the cure. I will post an update after I clean the contacts and verify there are no signs of overheating or failed components and if the problem is fixed.
did you try the fix?
My 2012 mustang GT 5.0 just went dead battery good lights still come on but once I turn the key forward no lights on the dash window don’t go up I’m Definitely about to go outside side and try this what I have to lose thank you I will up date late
Try replacing relay starter fuse on junction box some simple I had that problem with my 2010 gt
