Ir para o conteúdo principal
How to Repair Warped Eyeglasses Arm Joint and Replace the Screw
O que você precisa
  1. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 1, imagem 1 %32 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 1, imagem 2 %32 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw, How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 1, imagem 3 %32
    • Select a screw from the assorted eyeglasses screws box to begin the size-fitting process.
    • Start from the smaller sizes and work your way up until the screw body fits in the eyeglass frame hinge.
  2. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 2, imagem 1 %32 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 2, imagem 2 %32 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 2, imagem 3 %32
    • Place the screw into the end piece of the eyeglasses.
    • If the screw does not fit, repeat Steps 1 and 2 until you find a match.
    • Set the screw aside once you have the perfect fit.
  3. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 3, imagem 1 %32 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 3, imagem 2 %32 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 3, imagem 3 %32
    • Position the pliers so that both sides of the arm joint are on the inside of the pliers.
    • Apply slight pressure to the pliers to bend the warped arm joint back into place.
    • Too much pressure might break the arm joint or make the arm joint too tight for the next step, so be very mindful about the pressure!
  4. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 4, imagem 1 %32 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 4, imagem 2 %32
    • Align the arm joint to the end piece of the eyeglasses.
    • If the two pieces do not align or the fit is too loose, repeat Step 3 to adjust the arm joint.
  5. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 5, imagem 1 %32 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 5, imagem 2 %32 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Place the screw through the arm joint and end piece using tweezers.
  6. How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 6, imagem 1 %32 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 6, imagem 2 %32 How to Repair Warped Eyeglasses Arm Joint and Replace the Screw: passo 6, imagem 3 %32
    • Tighten the screw with the screwdriver.
    • Depending on your eyeglasses screws, choose the appropriate screwdriver size and shape.
Conclusão
To disassemble your device, follow these instructions in reverse order.
Jaclyn Nguyen
Membro desde: 02/01/23
133 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-4, Andersen Winter 2023 Membro de UC Davis, Team 4-4, Andersen Winter 2023
UCD-ANDERSEN-W23S4G4
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 82
Duração total: 1,110
