Ir para o conteúdo principal
How to Repair Timex t121b Buttons
O que você precisa
  1. How to Repair Timex t121b Buttons, How to Repair Timex t121b Buttons: passo 1, imagem 1 %32 How to Repair Timex t121b Buttons, How to Repair Timex t121b Buttons: passo 1, imagem 2 %32 How to Repair Timex t121b Buttons, How to Repair Timex t121b Buttons: passo 1, imagem 3 %32
    • Unplug the alarm clock from the power.
    • Flip the alarm clock upside down and open the lid.
    • Take out the batteries and leave them aside.
  2. How to Repair Timex t121b Buttons: passo 2, imagem 1 %32 How to Repair Timex t121b Buttons: passo 2, imagem 2 %32 How to Repair Timex t121b Buttons: passo 2, imagem 3 %32
    • Use a Phillips screwdriver to remove all of the screws on the underside of the clock.
    • Carefully lift the cover and lay it down as shown in the third image.
  3. How to Repair Timex t121b Buttons: passo 3, imagem 1 %32 How to Repair Timex t121b Buttons: passo 3, imagem 2 %32 How to Repair Timex t121b Buttons: passo 3, imagem 3 %32
    • Flip the alarm clock until the top of the clock is facing down.
    • Take out the first screw (1.2 mm Phillips) as shown in the second image.
    • Take out the second screw (1.2 mm Phillips) as shown in the third image.
  4. How to Repair Timex t121b Buttons: passo 4, imagem 1 %32 How to Repair Timex t121b Buttons: passo 4, imagem 2 %32 How to Repair Timex t121b Buttons: passo 4, imagem 3 %32
    • Carefully check the buttons and make sure you are able to press all the buttons.
    • Clean any dust that might be interfering with the buttons.
    • Adjust and push the alarm slide button to its proper position as shown in the third image.
  5. How to Repair Timex t121b Buttons: passo 5, imagem 1 %32 How to Repair Timex t121b Buttons: passo 5, imagem 2 %32 How to Repair Timex t121b Buttons: passo 5, imagem 3 %32
    • Put the board back in place and place the first screw (1.2 mm Phillips) as shown in the first image.
    • Place the second screw (1.2 mm Phillips) as shown in the second image.
    • Carefully place the two halves of the clock back together and put all 4 screws (1.2 mm Phillips) as shown in the third image.
    • Open the back lid and place the batteries.
Conclusão
Jad Abdalnor
Membro desde: 01/18/22
121 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 21
Duração total: 260
