Ir para o conteúdo principal
How to Repair Molded Baseboards
O que você precisa
  1. How to Repair Molded Baseboards, How to Repair Molded Baseboards: passo 1, imagem 1 %32
    • Sand the damaged area with the 120 grit sandpaper or a sanding block.
    • Use a utility knife to smooth rougher areas if needed.
  2. How to Repair Molded Baseboards: passo 2, imagem 1 %32
    • Lightly coat the damaged area with wood glue.
  3. How to Repair Molded Baseboards: passo 3, imagem 1 %32 How to Repair Molded Baseboards: passo 3, imagem 2 %32
    • Build up the affected areas with the wood filler. This can be applied with your hands (as individual product safety allows), a spare piece of cardboard, or a popsicle stick.
    • Allow to dry a few hours or overnight (based on product directions).
  4. How to Repair Molded Baseboards: passo 4, imagem 1 %32
    • Cut or fold the 150 grit sandpaper sheet into various pieces to allow proper fit into the various grooves of your baseboard.
  5. How to Repair Molded Baseboards: passo 5, imagem 1 %32
    • Sand the dried wood filler with 150 grit sandpaper.
    • Start from the inside of the baseboard and move out toward the repaired area.
    • Avoid a sawing or back-and-forth motion with the sandpaper to achieve a smooth finish.
  6. How to Repair Molded Baseboards: passo 6, imagem 1 %32
    • Wipe with a slightly damp cloth.
    • Repeat step 3 as needed.
    • Wait at least one hour.
    • Repeat step 6 for the final sanding.
  7. How to Repair Molded Baseboards: passo 7, imagem 1 %32
    • Touch-up with matching paint as needed.
Conclusão
Clean-up should be a breeze, and you should be ready to finish your weekend with loads of time to spare after this simple project!
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 89
Ao todo: 10,867
