Ir para o conteúdo principal
How to Repair Malfunctioning Cordless Window Blinds
O que você precisa
  1. How to Repair Malfunctioning Cordless Window Blinds, How to Repair Malfunctioning Cordless Window Blinds: passo 1, imagem 1 %32 How to Repair Malfunctioning Cordless Window Blinds, How to Repair Malfunctioning Cordless Window Blinds: passo 1, imagem 2 %32 How to Repair Malfunctioning Cordless Window Blinds, How to Repair Malfunctioning Cordless Window Blinds: passo 1, imagem 3 %32
    • Remove the clips that keep the blinds attached to the wall.
    • These should easily slide out.
  2. How to Repair Malfunctioning Cordless Window Blinds: passo 2, imagem 1 %32 How to Repair Malfunctioning Cordless Window Blinds: passo 2, imagem 2 %32
    • Slide the angling rod off its hook.
  3. How to Repair Malfunctioning Cordless Window Blinds: passo 3, imagem 1 %32
    • Locate the pulley where the string exits the top housing.
    • The string has likely fallen off of the pulley, causing too much resistance for the retraction mechanism to work properly.
  4. How to Repair Malfunctioning Cordless Window Blinds: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Pull the shaft partially out of the housing.
    • The shaft is not supposed to come out of the housing all of the way. This step is meant to bend the shaft just enough so that the tweezers can reach behind it.
  5. How to Repair Malfunctioning Cordless Window Blinds: passo 5, imagem 1 %32
    • From the bottom of the housing, pull on the string that runs through the blinds.
    • This step is meant to add slack in the string.
    • Hold the slack by putting a finger through the loop it makes.
  6. How to Repair Malfunctioning Cordless Window Blinds: passo 6, imagem 1 %32
    • While holding the slack with your middle finger, and the shaft with your index finger, use the tweezers to grab on to the string from the top side of the housing.
    • Pull the string up and toward you as you remove your middle finger from the loop.
  7. How to Repair Malfunctioning Cordless Window Blinds: passo 7, imagem 1 %32 How to Repair Malfunctioning Cordless Window Blinds: passo 7, imagem 2 %32
    • Test the blinds to see if they are working. If they aren't, check to see if the string has been realigned on the pulley and repeat the steps as necessary.
Conclusão
Enjoy your retractable blinds!
Adam Porter
Membro desde: 02/26/22
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 83
Últimos 30 dias: 373
Duração total: 30,933
