Ir para o conteúdo principal
How to Repair GPS
O que você precisa
Instruções em vídeo
Conclusão
Uma outra pessoa concluiu este guia.
marekaureliuszszulc
Membro desde: 04/06/17
143 Reputação
Autoria de 1 guia
1Comentário do guia
Hi sir, i have the exact same problem with GPS. At first i thought it’s a software problem so i tried every way i could find on the internet but none of them seem to work.
I read so many Zenfone user using your method solve the problem. I’d like to try it as well hoping my GPS will fixed.
My question is :
the GPS antenna separated in two parts which connected to two connectors. As i see the pics in your vid, do i have to connect only the upper part of antenna to the upper connector? and is it necessary to put the other end of cooper wire to the small hole below the sim card slot?
Any answer will be much appreciated.
Thank you from Bali
Vickkal Kristianes - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 69
Ao todo: 2,207
