Ir para o conteúdo principal
How to Repair Frayed Shoelaces
O que você precisa
  1. How to Repair Frayed Shoelaces, How to Repair Frayed Shoelaces: passo 1, imagem 1 %32
    • Cut of the excess frayed shoelace.
  2. How to Repair Frayed Shoelaces: passo 2, imagem 1 %32 How to Repair Frayed Shoelaces: passo 2, imagem 2 %32 How to Repair Frayed Shoelaces: passo 2, imagem 3 %32
    • Slip the entire heat shrink tube over the frayed part of the lace.
    • Make sure to clump the frayed part of the lace together when inserting the tubing.
    • Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
  3. How to Repair Frayed Shoelaces: passo 3, imagem 1 %32 How to Repair Frayed Shoelaces: passo 3, imagem 2 %32
    • After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction.
    • Remember not to go beyond the frayed part of the lace with tubing.
  4. How to Repair Frayed Shoelaces: passo 4, imagem 1 %32 How to Repair Frayed Shoelaces: passo 4, imagem 2 %32 How to Repair Frayed Shoelaces: passo 4, imagem 3 %32
    • Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around.
    • Make sure to heat the heat shrink tube all the way around, heating the entire tube
    • When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
  5. How to Repair Frayed Shoelaces: passo 5, imagem 1 %32
    • Repeat these steps on all the other frayed shoelaces.
Conclusão
When the heat shrink tube is completely shrunk to appropriate size, you are finished. Repeat steps 1-4 depending on how many frayed laces are present.
14 outras pessoas executaram este guia.
Anirudh Jain
Membro desde: 04/09/15
605 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 28-6, Green Spring 2015 Membro de Cal Poly, Team 28-6, Green Spring 2015
CPSU-GREEN-S15S28G6
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 34
Duração total: 11,875
