Ir para o conteúdo principal
How to Repair Damaged Door or Window Casing
O que você precisa
  1. How to Repair Damaged Door or Window Casing, How to Repair Damaged Door or Window Casing: passo 1, imagem 1 %32
    • Sand down the damaged area of the trim using the block sanding sponge to make a smooth surface.
  2. How to Repair Damaged Door or Window Casing: passo 2, imagem 1 %32
    • Wipe off the excess dust from sanding with a wash cloth.
  3. How to Repair Damaged Door or Window Casing: passo 3, imagem 1 %32
    • Apply Dap drydex spackling to to the damaged area of the trim using a 1" plastic putty knife.
    • Allow the spackling to dry per the directions on the label.
  4. How to Repair Damaged Door or Window Casing: passo 4, imagem 1 %32
    • Use the block sanding sponge to smooth out the surface of the trim to match the crevices of the trim.
  5. How to Repair Damaged Door or Window Casing: passo 5, imagem 1 %32
  6. How to Repair Damaged Door or Window Casing: passo 6, imagem 1 %32 How to Repair Damaged Door or Window Casing: passo 6, imagem 2 %32
    • Tape the edges around the damaged area of the trim with masking tape.
  7. How to Repair Damaged Door or Window Casing: passo 7, imagem 1 %32 How to Repair Damaged Door or Window Casing: passo 7, imagem 2 %32
    • Paint the trim to match the original color.
    • Allow the paint to dry before removing the tape.
Conclusão
Repairing chipped and/or broken door or window casing in the home as a do-it-yourself project overall saves time and money. There is no hassle of having to take off of work to meet the installers, no outrageous costs for materials and proper equipment, and no stress because this guide has everything necessary to complete the repair. So have fun, good luck, and happy fixing.
Uma outra pessoa concluiu este guia.
Celeste Conroy
Membro desde: 07/11/17
128 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team S1-G6, Rauch Summer 2017 Membro de Texas Tech, Team S1-G6, Rauch Summer 2017
TTU-RAUCH-SU17S1G6
3 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 13
Ao todo: 2,335
