Ir para o conteúdo principal
How to Repair Bumped Corners on a Hardcover Book
O que você precisa
  1. How to Repair Bumped Corners on a Hardcover Book, How to Repair Bumped Corners on a Hardcover Book: passo 1, imagem 1 %32
    • Open the book to one cover corner.
    • Apply the PVA glue on a bumped corner using the glue tip or a small paintbrush.
    • Coat the worn layers with the same paintbrush.
    • The corner layers should be well-saturated for them to stick together.
  2. How to Repair Bumped Corners on a Hardcover Book: passo 2, imagem 1 %32
    • Pinch the corner layers together with a piece of cloth.
    • Remove excess glue with paper towels or a cloth rag.
    • Pinching the corner layers will help them stick together with the glue.
    • The cloth will provide minimal mess and remove excess glue.
  3. How to Repair Bumped Corners on a Hardcover Book: passo 3, imagem 1 %32
    • Wrap the entire corner with a small sheet of wax paper.
    • The wax paper will protect the work done on the corner for the next steps.
  4. How to Repair Bumped Corners on a Hardcover Book: passo 4, imagem 1 %32
    • Put one piece of wood chipboard on each side of the corner.
    • The wood chipboard will prevent the book corner from denting in the next step.
  5. How to Repair Bumped Corners on a Hardcover Book: passo 5, imagem 1 %32
    • Clamp everything together.
    • Let everything dry for 30 minutes.
    • This book-binding method ensures enough time and support for the bumped corner to transform into better condition.
  6. How to Repair Bumped Corners on a Hardcover Book: passo 6, imagem 1 %32 How to Repair Bumped Corners on a Hardcover Book: passo 6, imagem 2 %32
    • Remove the clip, boards, and wax paper to see the results.
    • Repeat steps 1-6 for any other bumped book corner(s).
Conclusão
And that's bookbinding! Enjoy your book in new condition.
Salimah Rogers
Membro desde: 04/22/24
160 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-6, Whithaus Spring 2024 Membro de UC Davis, Team 3-6, Whithaus Spring 2024
UCD-WHITHAUS-S24S3G6
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 65
Duração total: 200
