Ir para o conteúdo principal
How to Repair Broken Concrete Steps
O que você precisa
  1. How to Repair Broken Concrete Steps, How to Repair Broken Concrete Steps: passo 1, imagem 1 %32
    • Remove any excess tiles from the staircase that need repair.
    • Make sure to apply rough grip gloves and eye-protection.
  2. How to Repair Broken Concrete Steps: passo 2, imagem 1 %32
    • Use a claw hammer and chisel to flatten/smooth the surface of concrete to reduce any unsound or flaking stones.
    • Be sure to hammer and chisel within the flat surface; don't dig too deep into the stairs.
  3. How to Repair Broken Concrete Steps: passo 3, imagem 1 %32
    • Apply a wet, stiff bristle brush to remove dusted concrete.
    • Firmly and aggressively press against the brush onto the concrete, to ensure all flakes are absent.
    • Make sure to leave no holes or corners untouched before moving onto the next step.
  4. How to Repair Broken Concrete Steps: passo 4, imagem 1 %32
    • Insert the larger chisel into the bucket of the quick-setting cement, in the motion of mixing.
    • The amount of cement should cover 1/3rd of the chisel before reapplying.
  5. How to Repair Broken Concrete Steps: passo 5, imagem 1 %32
    • Slowly smear the quick-setting cement onto the surface of the smooth concrete.
    • Use one of the faces of the chisel to press against the concrete with paste.
  6. How to Repair Broken Concrete Steps: passo 6, imagem 1 %32
    • Using a margin trowel, press firmly towards the quick-setting cement to flatten the concrete from a left-to-right motion each time.
    • Pressing firmly and slowly will result in a more professional look.
  7. How to Repair Broken Concrete Steps: passo 7, imagem 1 %32
    • After applying the quick-setting cement, reapply your tiles and wait 5-7 hours before hardening.
    • If no tiles are needed for your staircase, wait 5 minutes when surface becomes firm to mold and shape the concrete.
Conclusão
By completing these easy steps on repairing concrete steps, you’re finishing repair will provide a pleasing look and safety for the environment.
3 outras pessoas executaram este guia.
Barvee
Membro desde: 05/10/20
226 Reputação
Autoria de 1 guia
1Comentário do guia
Thanks for the repair pointers!
Nikki Mcmullen - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 44
Ao todo: 1,665
