Introdução
When you drop your makeup powder and crack it, it can get messy because the powder will be broken up and loose. When this happens, it can be upsetting to think that you will need to spend a lot of money to buy a new item of makeup when you still have a lot of the desired product. This guide will teach you how to put the powder back together so that your makeup will be compact again and will help you save your money.
O que você precisa
Set a paper towel down on your workspace to catch any spills during the repair process.
Using the toothpick, break up the powder into smaller pieces to ensure that all the product is lifted off of the container that it is held in.
The reader will be able to reassemble their broken makeup powder by reading this easy-to-follow tutorial.
Uma outra pessoa concluiu este guia.
