Ir para o conteúdo principal
How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On
O que você precisa
Vídeo de Apresentação
  1. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: passo 1, imagem 1 %32
    • As you can see from the photo, the negative pole of the battery is connected to the main board through the aluminum body of the keyboard.
    • There are two contact areas:
    • Between the battery cover and the KB aluminum body
    • Between the power button assemble and the KB aluminum body
    • If the device has a power problem, we need to check and clean these two places
  2. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: passo 2, imagem 1 %32 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: passo 2, imagem 2 %32 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Battery replacement: passo 2, imagem 3 %32
    • Use a Coin to remove the metal battery screw cover
    • Change the batteries (AA) and test the keyboard
    • If the keyboard does not work, go to the next step
  3. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: passo 3, imagem 1 %32 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: passo 3, imagem 2 %32 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Cleaning battery cover area: passo 3, imagem 3 %32
    • Use cotton buds, Toothpicks and Isopropyl Alcohol to clean the contact area and the battery cap.
    • Test the device and f the keyboard does not work, go to the next step
  4. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: passo 4, imagem 1 %32 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: passo 4, imagem 2 %32 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On, Logic Board Removal Part 1: passo 4, imagem 3 %32
    • Remove the plastic cap from the middle on the tube and disconnect the KB flex cable
    • There are a screw secured the BT antenna, remove it
    • Slide the board out.
    • Be careful for the KB Flex Cable
  5. How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: passo 5, imagem 1 %32 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: passo 5, imagem 2 %32 How to Repair Apple Wireless Keyboard A1314 - Doesn't Turn On: passo 5, imagem 3 %32
    • Use tweezers or a sharp metal tool and slightly bend the contact plate outwards
    • Clean the tube and the contact plate
    • Install back the logic board plate and be careful for the flex
Conclusão
5 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
187.973 Reputação
330 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
311 Membros
1.197 Guias de autoria
2 comentários
Add a little dielectric grease to the battery end cap. Had considerable corrosion despite batteries not leaking. Strange design.
George Walsh - Responder
Wow! This fixed actually worked! I was about to thrown this A1314 keyboard out (2009 model)! You can remove the plastic "cap" with a precision flathead screwdriver. Also, be careful when disassembling the ribbon cable - there is a plastic retaining clip holding it in place. Use the precision screwdriver to carefully release the tabs on either side and then pop it out. The ribbon cable will then easily side out. By the way...I'm typing this comment on my newly fixed wireless keyboard! Thanks again!
Vic - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 84
Últimos 30 dias: 445
Duração total: 9,756
